MacBook Unibody Model A1278 Mid Wall Replacement
    1. MacBook Unibody Model A1278 Mid Wall Replacement, Access Door: step 1, image 1 of 1
      • With the case closed, place the Unibody top-side down on a flat surface.
      • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
      Ask FixBot
    2. MacBook Unibody Model A1278 Mid Wall Replacement: step 2, image 1 of 1
      • The access door should now be raised enough to lift it up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 Mid Wall Replacement, Battery: step 3, image 1 of 1
      • Be sure the access door release latch is vertical before proceeding.
      • Grab the white plastic tab and pull the battery up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 Mid Wall Replacement, Lower Case: step 4, image 1 of 1
      • Remove the following eight screws securing the lower case to the chassis:
      • One 3 mm Phillips screw.
      • Four 3.5 mm Phillips screws.
      Ask FixBot
    2. MacBook Unibody Model A1278 Mid Wall Replacement: step 5, image 1 of 1
      • Using both hands, lift and remove the lower case off the upper case.
      Ask FixBot
    1. MacBook Unibody Model A1278 Mid Wall Replacement, Mid Wall: step 6, image 1 of 1
      • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
      Ask FixBot
    2. MacBook Unibody Model A1278 Mid Wall Replacement: step 7, image 1 of 1
      • Lift the mid wall out of the upper case.
      Ask FixBot
7 other people completed this guide.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 98
All Time: 22,851
