MacBook Unibody Model A1278 Hard Drive Replacement
    1. MacBook Unibody Model A1278 Hard Drive Replacement, Access Door: step 1, image 1 of 1
      • With the case closed, place the Unibody top-side down on a flat surface.
      • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
      Ask FixBot
    2. MacBook Unibody Model A1278 Hard Drive Replacement: step 2, image 1 of 1
      • The access door should now be raised enough to lift it up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 Hard Drive Replacement, Battery: step 3, image 1 of 1
      • Be sure the access door release latch is vertical before proceeding.
      • Grab the white plastic tab and pull the battery up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
      • Remove the single Phillips screw securing the hard drive bracket to the upper case.
      • This screw is captive to the hard drive bracket.
      Ask FixBot
    2. MacBook Unibody Model A1278 Hard Drive Replacement: step 5, image 1 of 1
      • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
      • Lift the hard drive out of the chassis, minding the cable attaching it to the computer.
      Ask FixBot
    3. MacBook Unibody Model A1278 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
      • Hard drive remains.
      Ask FixBot
    1. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: step 7, image 1 of 1
      • Remove the two T6 Torx screws from each side of the hard drive (four screws total).
      • You'll need to transfer these screws to your new hard drive if you're changing drives.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      Ask FixBot
431 other people completed this guide.
8 Guide Comments
Radio shack has a small kit with assorted bits that includes all of the t bits
Ryan - Reply Share
just to be save a quick .. use super duper first on your new hdd to clone the old one... (if possible) and after installing... its like you have the same drive... no loss of files.... easy does it!
Britt - Reply Share
Very easy and worth the upgrade
Ivan Juarez - Reply Share
The model A1278 in front of me doesn't look like the above. It has 10 screws holding a single piece base onto the body, and not a single quick-release catch in sight. The battery bay looks different as well, but removing the HDD is just as easy.
StripyDonkey - Reply Share
That is because you are looking at a MacBook Pro A1278, not the MacBook Unibody. Apple made the regular MacBook in an aluminum enclosure in 2008 and the following aluminum model was changed to be called the MacBook Pro.
Frank Malinowski - Reply Share
Past 24 Hours: 8
Past 7 Days: 113
Past 30 Days: 338
All Time: 334,279
