MacBook Pro 16" 2021 Trackpad Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad: step 1, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad: step 1, image 2 of 2
      • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
      • Ten 5 mm screws
      • Three 5.8 mm screws
      • These screws all look similar—be careful not to mix them up.
      • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
      • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
      Ask FixBot
    2. MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: step 2, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: step 2, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: step 2, image 3 of 3
      • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
      • Carefully feed the trackpad's ribbon cable through its slot in the frame.
      Ask FixBot
    3. MacBook Pro 16" 2021 Trackpad Replacement: step 3, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement: step 3, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement: step 3, image 3 of 3
      • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
      • Remove the trackpad assembly.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
Alex Diaz-Kokaisl
249,131 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,246 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 279
