MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement
  1. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
    Ask FixBot
  2. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    Ask FixBot
  3. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement, Battery Connector: step 3, image 1 of 2 MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement, Battery Connector: step 3, image 2 of 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
    Ask FixBot
  4. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 4, image 1 of 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    Ask FixBot
  5. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement, Optical Drive: step 5, image 1 of 1
    • Disconnect the camera cable connector from its socket on the logic board.
    • Do not lift up on the cable as you disconnect it from the logic board. Pull the cable parallel to the face of the logic board.
    Ask FixBot
  6. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
    Ask FixBot
  7. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 7, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
    Ask FixBot
  8. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 8, image 1 of 2 MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 8, image 2 of 2
    • Remove following two screws:
    • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
    • One 8.6 mm Phillips screw
    • One 3.9 mm Phillips screw
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
    Ask FixBot
  9. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 9, image 1 of 1
    • Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
    Ask FixBot
  10. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement: step 10, image 1 of 1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
    Ask FixBot
  11. MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement, Optical Drive Cable: step 11, image 1 of 2 MacBook Pro 15" Unibody Mid 2012 Optical Drive Cable Replacement, Optical Drive Cable: step 11, image 2 of 2
    • Pull the optical drive cable out of the optical drive.
    • Be sure to pull by the edges of the connector, not by the cable itself.
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
    Ask FixBot
13 other people completed this guide.
Andrew Optimus Goldheart
515,323 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 64
All Time: 7,238
