MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement
  1. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
    Ask FixBot
  2. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    Ask FixBot
  3. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Battery Connector: step 3, image 1 of 2 MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Battery Connector: step 3, image 2 of 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
    Ask FixBot
  4. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: step 4, image 1 of 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    Ask FixBot
  5. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Left Fan: step 5, image 1 of 1
    • Remove the following three screws securing the left fan to the logic board:
    • Two 3.5 mm T6 Torx screws.
    • One 4.2 mm T6 Torx screw.
    Ask FixBot
  6. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: step 6, image 1 of 3 MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: step 6, image 2 of 3 MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: step 6, image 3 of 3
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket.
    • The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    Ask FixBot
  7. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: step 7, image 1 of 1
    • Lift the left fan out of the upper case.
    Ask FixBot
47 other people completed this guide.
Andrew Optimus Goldheart
515,323 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,603 Guides authored
3 Guide Comments
Are you sure that’s the left fan and not the right ?
If you click on the buy these parts” link it shows a picture of a different fan, the one on the other side of the MBP.
Would be nice if you could clear this up.
Thank you.
Konstantinos Bonotis - Reply Share
Yes its the left fan when you are typing on the Mac & that is what it’s called. When you replace it however it’s on the RHS of the upside down Mac with the motherboard exposed.
Stephen Fry - Reply Share
after cleaning the fans from dust, my left fan is making constantly noise. it’s not loud but it is annoying by time. can i fix this or is it because the fan is damaged?
butch coolidge - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 79
All Time: 22,407
