Introduction
Use this guide to replace a broken left speaker. Replacing the left speaker requires removal of the logic board.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
Tilt the battery away from the logic board enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
16 other people completed this guide.
4 Guide Comments
I changed the left speaker with another one got on ebay. but still it has refused to work. what other methods can i try?
Stellar guide, easier than it looks at first, new left speaker from China, perfect sound once again in this 11-year old MBP.
I did this disassembly and reassembly in 2018 when I thought my GPU had another breakdown. Should have replaced the left speaker back then. In the end it was the RAM and replacing 4GB with 8GB did the job. Still have to do this again to replace the speaker, if I can get one on ebay. I brought it to a repair shop to fix the capacitor of the GPU board in 2019. Hopefully I will never again have to pay Apple 350€ again, to fix a problem they caused with areplacment of a faulty part with a NEW faulty part! Real Geniuses those people .. when it comes to making money. The company was better when Steve Jobs was still alive and shareholders got nothing for their shares!
Todays Macs are a nightmare to repair. What a difference my old Quicksilver PowerMac G4 is! You press one button and the whole chassis opens up for repair, maintenance or upgrades without removing one screw!
Great guide! Reversing Step 19 was most definitely the most challenging part. Everything else is golden!
I have had this old computer since the summer of 2010 and it has been used as my test bed for so many things.
Thank you.
