MacBook Pro 15" Unibody Mid 2010 LCD Replacement
    1. MacBook Pro 15" Unibody Mid 2010 LCD Replacement, Lower Case: step 1, image 1 of 1
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 2, image 1 of 1
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      Ask FixBot
    1. MacBook Pro 15" Unibody Mid 2010 LCD Replacement, Battery: step 3, image 1 of 1
      • Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
      • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
      • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 4, image 1 of 1
      • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
      • Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
      Ask FixBot
    3. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 5, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 5, image 2 of 2
      • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
      • Do not try to completely remove the battery just yet.
      Ask FixBot
    4. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 6, image 1 of 1
      • Tilt the battery away from the logic board enough to access the battery cable connector.
      • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
      • Pull the battery cable connector away from the center of the logic board.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Ask FixBot
    1. MacBook Pro 15" Unibody Mid 2010 LCD Replacement, Display: step 7, image 1 of 1
      • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 8, image 1 of 1
      • Pull the camera cable connector straight out of its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the optical drive opening.
      Ask FixBot
    3. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 9, image 1 of 1
      • Use the tip of a spudger to pry the three antenna connectors up off the AirPort/Bluetooth board.
      Ask FixBot
    4. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 10, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 10, image 2 of 2
      • De-route all three antenna cables from their channels in the AirPort/Bluetooth housing.
      • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
      Ask FixBot
    5. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 11, image 1 of 1
      • Remove the following two screws securing the AirPort/Bluetooth housing to the upper case:
      • One 3.8 mm Phillips
      • One 8.6 mm Phillips
      Ask FixBot
    6. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 12, image 1 of 1
      • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
      Ask FixBot
    7. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 13, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 13, image 2 of 2
      • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
      • Remove the antenna/camera cable retainer from the upper case.
      Ask FixBot
    8. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 14, image 1 of 1
      • Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
      • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
      Ask FixBot
    9. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 15, image 1 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 15, image 2 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 15, image 3 of 3
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      Ask FixBot
    10. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 16, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 16, image 2 of 2
      • Remove the 8.6 mm Phillips screw securing the display data cable retainer to the upper case.
      • Remove the display data cable retainer from the upper case.
      Ask FixBot
    11. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 17, image 1 of 1
      • Remove two of the three 6 mm T6 Torx screws securing the left side of the display to the upper case.
      Ask FixBot
    12. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 18, image 1 of 1
      • Open your MacBook Pro so the display is perpendicular to the upper case.
      • Place your opened MacBook Pro on a table as pictured.
      • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the upper display bracket.
      Ask FixBot
    13. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 19, image 1 of 1
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • Remove the last remaining T6 Torx screw securing the display to the upper case.
      Ask FixBot
    14. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 20, image 1 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 20, image 2 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 20, image 3 of 3
      • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
      • Rotate the display slightly away from the upper case.
      • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
      Ask FixBot
    1. MacBook Pro 15" Unibody Mid 2010 LCD Replacement, Front Display Glass: step 21, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement, Front Display Glass: step 21, image 2 of 2
      • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
      • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
      • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
      • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
      • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 22, image 1 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 22, image 2 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 22, image 3 of 3
      Tool used on this step:
      Heavy-Duty Suction Cups (Pair)
      $16.95
      Buy
      • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
      • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
      • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
      • Slowly and gently pull the corner of the display glass up off the display assembly.
      • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
      Ask FixBot
    3. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 23, image 1 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 23, image 2 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 23, image 3 of 3
      • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
      • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
      • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
      Ask FixBot
    4. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 24, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 24, image 2 of 2
      • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
      • Attach a suction cup along the right side of the front glass panel.
      • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
      • Continue working along the right edge of the front display glass until it is separated from the display.
      • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
      Ask FixBot
    5. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 25, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 25, image 2 of 2
      • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
      • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
      • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
      Ask FixBot
    6. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 26, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 26, image 2 of 2
      • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
      • Attach a suction cup near the upper left corner of the glass display panel.
      • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
      • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
      Ask FixBot
    7. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 27, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 27, image 2 of 2
      • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
      • Attach a suction cup along the left side of the front glass panel.
      • Continue working along the left edge of the front display glass until it is separated from the display.
      Ask FixBot
    8. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 28, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 28, image 2 of 2
      • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
      • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
      • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
      Ask FixBot
    9. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 29, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 29, image 2 of 2
      • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
      • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
      Ask FixBot
    10. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 30, image 1 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 30, image 2 of 3 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 30, image 3 of 3
      • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
      • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
      • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
      • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
      • Reapply the piece of tape covering the camera cable socket.
      Ask FixBot
    1. MacBook Pro 15" Unibody Mid 2010 LCD Replacement, LCD: step 31, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement, LCD: step 31, image 2 of 2
      • Slide the clutch cover toward the right edge of the display.
      • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
      • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 32, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 32, image 2 of 2
      • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
      • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
      • Lift the clutch cover up off the front bezel and set it aside.
      • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
      Ask FixBot
    3. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 33, image 1 of 1
      • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
      Ask FixBot
    4. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 34, image 1 of 1
      • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
      • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
      Ask FixBot
    5. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 35, image 1 of 1
      • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
      Ask FixBot
    6. MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 36, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 LCD Replacement: step 36, image 2 of 2
      • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
      • Pull the display data cable straight away from its socket on the LCD.
      • Lift the LCD out of the display assembly and set it aside.
      • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
      Ask FixBot
41 other people completed this guide.
8 Guide Comments
Everything in this guide is simple, except for tearing the glass plate off. I tried with a hairdryer (1200 Watt) first, without success. Then I used a hot air gun (at 400 deg. Celcius, about 750 Fahrenheit). It worked like a charm, but my rubber edge is somewhat shiny, and in one area there's a fingerprint now. Nevertheless, this operation saved me 400 Euros and I'm happy I did it.
arnebakker - Reply Share
I followed the guide and it worked very well. However, after heating the glass for removal I found the lower right corner to be the easiest. Then I used an old credit card to separate the glass from the frame by sliding it around. The hardest part was installing the new LCD panel and glass because of dirt particles and fingerprints. Great tutorial and guide.
RodriguezAlberto - Reply Share
For each step in the disassembly process, put the different screws into different shotglasses. Don't leave the screws lying around your desk unless you are a pro.
On a piece of paper, write the step #, and place the shotglass on it. If you have cats who might knock over your shotglasses, label them (the shotglasses, not the cats) using a piece of scotch tape. Then put them where they will not get destroyed by mischievous felines like a roll of toilet paper when you forget to close the bathroom door.
Read all comments in this section; they helped me a lot. DISCLAIMER: I am an idiot, and I confused the shotglasses containing cable restraints. I then spent about an hour trying to figure out where I'd gone wrong before I realized that the restraint in the photo was not the one in my hand. No wonder my father always gives me that look of disappointment when he sees me. Good luck!
Robert Burt - Reply Share
Thank you ifixit for making this sound easy. I just shattered my display.
fatlard1993 - Reply Share
Think you from algeria
fouad hamdouche - Reply Share
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 157
All Time: 117,017
