MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement
    1. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Lower Case: step 1, image 1 of 1
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: step 2, image 1 of 2 MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: step 2, image 2 of 2
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      Ask FixBot
    1. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Right Fan: step 3, image 1 of 3 MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Right Fan: step 3, image 2 of 3 MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Right Fan: step 3, image 3 of 3
      • Use a spudger to pry the fan connector straight up off the logic board.
      • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
      • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
      Ask FixBot
    2. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: step 4, image 1 of 1
      • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
      Ask FixBot
    3. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: step 5, image 1 of 1
      • Lift the right fan out of the upper case.
      Ask FixBot
56 other people completed this guide.
4 Guide Comments
Merci à iFixIt pour la qualité des pièces fournies et la rapidité à laquelle elles ont été expédiées.
Merci à Walter pour la clarté de son tuto, et aux traducteur pour la traduction !
Que du bonheur !
Fabrice CROMBEZ - Reply Share
Hello Walter, I have a mid 2009 macbook pro 15” and it has only one fan. I need to replace it. Which one should I buy?
bikkon yestal - Reply Share
thank you Team iFixit! this definitely is helping extend the life of my 10 year old (GASP!!!) MBP 15” A1286 !
Kahana - Reply Share
Same thing I said for the left fan:
Great guide, easy work to do! If I can do this, anyone can. If I can do this, someone who does not exist almost can. Not quite! But almost. I was happy to get that squalling and howling old fan out of my MacBook Pro, and thereby to end the squalling & howling I got from my family over the noise it made. Like the old one, the new fan works great, but it is new, and quiet, and I am thankful. Happy customer.
pstewart - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 107
All Time: 20,982
