MacBook Pro 15" Unibody Late 2011 Microphone Replacement
    1. MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Lower Case: step 1, image 1 of 1
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 2, image 1 of 1
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Battery Connector: step 3, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Battery Connector: step 3, image 2 of 2
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 4, image 1 of 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Left Fan: step 5, image 1 of 1
      • Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
      • In some models, these T6 Torx screws may be 3.1 mm long.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 6, image 1 of 3 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 6, image 2 of 3 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 6, image 3 of 3
      • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
      • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
      • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
      Ask FixBot
    3. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 7, image 1 of 1
      • Lift the left fan out of the upper case.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Logic Board: step 8, image 1 of 1
      • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 9, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 9, image 2 of 2
      • Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
      • Lift the right fan out of its opening in the logic board.
      Ask FixBot
    3. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 10, image 1 of 1
      • Pull the camera cable out of its socket on the logic board.
      • Don't lift upward on the camera cable as you disconnect it. Pulling upward on the cable may damage both the cable and the logic board. Pull the cable parallel to the face of the logic board.
      Ask FixBot
    4. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 11, image 1 of 1
      • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
      Ask FixBot
    5. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 12, image 1 of 1
      • Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
      Ask FixBot
    6. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 13, image 1 of 1
      • Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
      Ask FixBot
    7. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 14, image 1 of 1
      • Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
      • Pry up from beneath the wires.
      Ask FixBot
    8. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 15, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 15, image 2 of 2
      • Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
      • Lift the cover off the logic board and set it aside.
      Ask FixBot
    9. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 16, image 1 of 1
      • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
      Ask FixBot
    10. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 17, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 17, image 2 of 2
      • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
      Ask FixBot
    11. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 18, image 1 of 1
      • Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
      Ask FixBot
    12. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 19, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 19, image 2 of 2
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      Ask FixBot
    13. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 20, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 20, image 2 of 2
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Be sure you are flipping up the hinged retaining flap, not the socket itself.
      • Pull the keyboard backlight ribbon cable out of its socket.
      Ask FixBot
    14. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 21, image 1 of 1
      • Remove the following nine screws:
      • Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
      • Two 8 mm T6 Torx screws on the DC-In board
      Ask FixBot
    15. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 22, image 1 of 3 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 22, image 2 of 3 MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 22, image 3 of 3
      • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
      • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
      • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Left Speaker: step 23, image 1 of 1
      • Lift the microphone out of its recess in the left speaker housing.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 24, image 1 of 1
      • Remove the two 5 mm Phillips screws securing the left speaker to the logic board.
      Ask FixBot
    3. MacBook Pro 15" Unibody Late 2011 Microphone Replacement: step 25, image 1 of 1
      • If present, remove the small strip of black tape covering the left speaker connector.
      • Carefully pull the left speaker wires upward to lift the left speaker connector out of its socket on the logic board.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Microphone Replacement, Microphone: step 26, image 1 of 1
      • Carefully pull the microphone cables upward to lift the microphone connector out of its socket on the logic board.
      Ask FixBot
5 other people completed this guide.
1 Guide Comment
Thank you the directions were spot on.
J. D. Booth - Reply Share
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 105
All Time: 7,910
