MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement
    1. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement, Lower Case: step 1, image 1 of 1
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement: step 2, image 1 of 1
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement, Battery Connector: step 3, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement, Battery Connector: step 3, image 2 of 2
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement: step 4, image 1 of 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Remove two Phillips screws securing the hard drive bracket to the upper case.
      • These screws are captive to the hard drive bracket.
      Ask FixBot
    2. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement: step 6, image 1 of 1
      • Lift the retaining bracket out of the upper case.
      Ask FixBot
    3. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement: step 7, image 1 of 1
      • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
      Ask FixBot
    4. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement: step 8, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement: step 8, image 2 of 2
      • Remove the hard drive cable by pulling its connector straight away from the hard drive.
      Ask FixBot
    1. MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement, Hard Drive: step 9, image 1 of 2 MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement, Hard Drive: step 9, image 2 of 2
      • Remove two T6 Torx screws from each side of the hard drive (four screws total).
      • You'll need to transfer these screws to your new hard drive if you're changing drives.
      • If desired, peel the pull tab off your old hard drive and transfer it to the side of your new drive.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running. Many recent Macs may be able to use OS X Internet Recovery.
      Ask FixBot
139 other people completed this guide.
12 Guide Comments
Hi everyone! I have a question.
I'm not a super expert in computers, but I'm hoping to learn from this intelligent website.
I have a Laptop MacBook Pro 15' late 2011, and I would like to replace the hard drive to a higher so then I can update with better programs: like Adobe CC.
what I have is system Lion, memory 16 GB 1333 MHz DDR3, processor 2.2 GHz Intel Core i7
what would you suggest me for a better performance with up to date art programs?
Regards
Oliver - Reply Share
Oliver,
If I'm understanding you correctly you want to replace the HDD with a larger capacity drive. In that case, for the most part, it won't improve the performance dramatically. A solid state drive would be the biggest improvement in terms of drive speed. The overall storage size won't really speed up the machine it will just give you more room for programs and storage.
Hope that helps,
-b
woestmab - Reply Share
One upgrade is to increase spindle speed. Typically you'll have a 5400 rpm drive from Apple unless a faster drive was ordered (look up your drive's number on the Hardware Report on About this Mac). A 7200 rpm will give you better access times but will come at greater power consumption (shorter battery life). You'll be trading cost and capacity for speed with solid state drives (SSD) as they are typically smaller capacity but have no moving parts to wait for and may have lower power consumption. Hybrids (SSHD) combine both, and of this writing, go up to 1TB. They also will come with 5400 rpm speed for lower power consumption than 7200 rpm and will use the SSD part for frequently used data to increase speed. Just make sure the SSD or SSHD is compatible with your Mac and that any drive selected is no taller than 9.5mm or your bottom cover won't close.
Joe - Reply Share
It caused an error upon reinstall of the OS. You forgot to mention that disconnecting the battery would reset the date, and installing the OS without resetting the date would give a general message about the process failing with no mention of a problem with the date.
Getting into terminal mode and typing: date mmddhhmmyyyy will reset the date. The hours and minutes go in the middle and the first mm is the month.
wresnick - Reply Share
Phillips #0 Screwdriver! not #00, that's too small.
reichman - Reply Share
Past 24 Hours: 7
Past 7 Days: 52
Past 30 Days: 221
All Time: 154,948
