MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, Lower Case: step 1, image 1 of 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, RAM: step 3, image 1 of 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, RAM: step 3, image 2 of 2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
97 other people completed this guide.
1 Guide Comment
How is this easier than removing a drive? Its both relatively easy. Otherwise good guides.
Jr. - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 80
All Time: 41,868
