MacBook Pro 15" Retina Display Mid 2015 SSD Replacement
Views: 567K
View statistics:
Past 24 Hours:
37
Past 7 Days:
305
Past 30 Days:
1,491
All Time:
567,113
Comments: 170
84 comments on steps, 86 guide comments.
Go to guide comments
Completed: 308
308 people have marked this guide "completed." Will you be next?
Favorites: 46
46 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to upgrade or replace the solid-state drive in a MacBook Pro 15” Mid 2015. This MacBook Pro uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.14 Mojave (or a later macOS) before replacing the original SSD from your MacBook Pro. Most new SSDs require updated storage drivers not found in versions of macOS prior to macOS 10.14 Mojave.
Parts
Tools
    1. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.1 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 2, image 2 of 2
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 3, image 3 of 3
      • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
      • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, Battery Connector: step 4, image 1 of 1
      • Peel back the sticker covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 5, image 3 of 3
      • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
      • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, SSD: step 6, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 7, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 7, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: step 7, image 3 of 3
      • Lift the end of the SSD up enough to pass over the speaker directly behind it.
      • Do not lift the SSD too high, or you could damage the contacts or socket.
      • Pull the SSD straight out of its socket on the logic board.
      Ask FixBot
308 other people completed this guide.
Sam Goldheart
478,594 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
86 Guide Comments
So guys, I got a couple of questions:
1. Is this model (MBP Retina Mid 2015/MacBookPro11,4 ) really upgradable? https://www.datenreise.de/en/macbook-pro... says otherwise.
2. Samsung 850 EVO or Samsung 850 PRO would work with the model mentioned above?
Eduardo Delai Correa - Reply Share
Yes, it is upgradeable. At the time that article was published there was no drive on the market that would work. Now there is. No the Samsung 850 EVO or Pro would not work. As far as I know OWC is the only one that produces an after market drive that is compatible.
Chris Matlock - Reply Share
I couldn't find the SSD that Chris mentioned. Would you please point out the exact model?
Jerry Zhong - Reply Share
It’s the OWC Aura Pro X2, you can get it all the up to 2TB.
Stephen Agnew - Reply Share
I think you could purchase a pcie to M2 adapter and fit a Samsung 950 Pro in there. 960 Pro is coming out soon though with higher performance.
tonynca7 - Reply Share
Past 24 Hours: 37
Past 7 Days: 305
Past 30 Days: 1,491
All Time: 567,113
