MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement
Views: 72K
View statistics:
Past 24 Hours:
7
Past 7 Days:
51
Past 30 Days:
250
All Time:
71,674
Comments: 46
40 comments on steps, 6 guide comments.
Go to guide comments
Completed: 35
35 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to help you replace a scratched, scuffed, bent or broken bottom panel on your MacBook Pro 15" Retina Display Mid 2015.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.1 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: step 2, image 2 of 2
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: step 3, image 3 of 3
      • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
      • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
      Ask FixBot
35 other people completed this guide.
Andrew Optimus Goldheart
516,048 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
6 Guide Comments
Do we need two different screw drivers for this or is the recommended one enough?
Jamey Rassweiler - Reply Share
You need the recommended one for the lid an a torx T5 for the screws inside
Oros - Reply Share
hello i have a 2015 15” macbook pro nut i want them all custom to me so scraped off the paint to be clear back. ive seen many “clear looking stickers but they mostly look $@$*!&. have you herd of any copany selling a clearback housing and can only find stickers do you knaw any sites delling vlear hpusings?. the only other thing i can think of if have a friend #D print in clear and polish it till turns clear any ideas? i also wany yje top case vlrar slso but oe thing at a time
jae.good - Reply Share
I've had the back off my 2015 15" Retina MBP a few times, without any issues. I bequeathed it to my wife and now without warning there are several screws missing. I don't understand what happened, how can this be? (No, she didn't remove them just to prank me!)
Are new screws likely to stay in place, or is it more likely the screw sockets are damaged or stripped?
groblewis - Reply Share
I would try some loctite. The screws on mine had a small amount of the "green" version
Richard Peach - Reply Share
Past 24 Hours: 7
Past 7 Days: 51
Past 30 Days: 250
All Time: 71,674
