MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement
    1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.1 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 2, image 2 of 2
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 3, image 3 of 3
      • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
      • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, Battery Connector: step 4, image 1 of 1
      • Peel back the sticker covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 5, image 3 of 3
      • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
      • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, AirPort/Camera Cables: step 6, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, AirPort/Camera Cables: step 6, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, AirPort/Camera Cables: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
      • The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable.
      • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 7, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 7, image 2 of 2
      • Peel the right rubber cover up off the fan and fold it out of the way.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 8, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 8, image 2 of 2
      • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
      • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 9, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 9, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 9, image 3 of 3
      • Use your fingers to pull the AirPort/Camera cables up off the fan.
      • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
      • Carefully de-route the cables from the plastic cable guide.
      • On reassembly, there should be enough adhesive still on these cables to stick them back down to the fan.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, I/O Board Cable (Top): step 10, image 1 of 1
      • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 11, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 11, image 2 of 2
      • Remove the left connector cover.
      • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 12, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 12, image 2 of 2
      • Remove the right connector cover.
      • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 13, image 1 of 1
      • Peel the I/O board cable up from the adhesive securing it to the fan.
      • Remove the cable.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, Right Fan: step 14, image 1 of 1
      • Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
      • One 5.0 mm screw with a 2.0 mm long shoulder
      • One 4.0 mm screw with a wide head
      • One 4.4 mm screw
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 15, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 15, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 15, image 3 of 3
      • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 16, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 16, image 2 of 2
      • Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
      • The fan cable may be adhered to the logic board—to avoid tearing the cable, gently peel it up while lifting the fan.
      • Remove the fan.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement, SSD: step 17, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 18, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 18, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 18, image 3 of 3
      • Lift the end of the SSD up enough to pass over the speaker directly behind it.
      • Do not lift the SSD too high, or you could damage the contacts or socket.
      • Pull the SSD straight out of its socket on the logic board.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 19, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 19, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 19, image 3 of 3
      • Use the point of a spudger to flip up the locking mechanism on the I/O board connector.
      • Flip the spudger around and use the flat end to slide the I/O cable out of the connector.
      • Push on the opened locking mechanism for an easy way to slide the I/O cable out of the connector. This could help prevent accidental damage to the cable or connector contacts.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 20, image 1 of 1
      • Remove the two 3.1 mm T5 Torx screws from the I/O board.
      Ask FixBot
    5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 21, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Replacement: step 21, image 2 of 2
      • Slightly lift the interior edge of the I/O board and pull it toward the center of the MacBook, away from the side of the case.
      • Remove the I/O board.
      Ask FixBot
17 other people completed this guide.
Andrew Optimus Goldheart
515,547 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
123 Members
83,724 Guides authored
1 Guide Comment
Be _VERY_ careful with the connector on the end of the I/O cable. Especially since it abuts to the speaker. It is easy to insert it diagonally but that could break the edge pins on the connector. Step 19 of this job (and the inverse) needs at least three hands.
Bryan Lunt - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 113
All Time: 29,612
