MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement
    1. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.1 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 2, image 2 of 2
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 3, image 3 of 3
      • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
      • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement, Battery Connector: step 4, image 1 of 1
      • Peel back the sticker covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 5, image 3 of 3
      • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
      • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement, Heat Sink: step 6, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement, Heat Sink: step 6, image 2 of 2
      • Peel the rubber cover up off the right fan and fold it out of the way.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 7, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 7, image 2 of 2
      • Peel the rubber cover up off the left fan and fold it out of the way.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 8, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 8, image 2 of 2
      • Remove the small rubber cap from the screw at the end of the heat sink.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 9, image 1 of 1
      • Remove the following screws securing the heat sink to the logic board:
      • One 3.8 mm T5 Torx screw
      • Two 3.4 mm T5 Torx screws
      • When you remove these screws, springy metal brackets securing the heat sink will be released. Take care not to lose these screws when the brackets spring free.
      • One 5.6 mm T5 Torx screw
      Ask FixBot
    5. MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 10, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement: step 10, image 2 of 2
      • Flip the two spring clamps out of the way of the heat sink.
      • Remove the heat sink from the MacBook Pro.
      • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
      • If you are using a model with dual graphics, be sure to remove the four screws where the GPU die is before attempting to remove the heatsink.
      Ask FixBot
96 other people completed this guide.
Andrew Optimus Goldheart
515,529 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
123 Members
83,052 Guides authored
12 Guide Comments
On my macbook Pro 2015 it has an extra Square on the heatsink to cover the graphics card. So the Pictures does not look right on this guide. I would share my pictures but it’s not possible in the comments.
Mark Barner - Reply Share
I don’t have much to add other than that these squares on the GPU and CPU were hindering my ability to completely clean off the previous thermal paste. I actually would like to remove the squares, but would like to hear from folks who might have a sense of how essential it is for thermal transfer (or any other purpose it serves).
Rahul S - Reply Share
Hey guys when I refreshed the thermal paste on my 2015 15” (top spec) mbp, I noticed four little metallic sponges in that area, one of those came off… I still have it, how critical is it? Should I replace it? If so are there any guides?
Many thanks
AlexMorse - Reply Share
I have the same issue as well— 2 of mine came off, and I just stuck them back where they were before and let the pressure of the heat sink hold it in place for now. But any expertise on this issue is appreciated!
I too am missing some of those "little metallic sponges". Has anyone found a good replacement for them. I cannot find them online. I'm sure it's because I don't know their "official" name. Maybe I can make my own from thermal pads?
rfmorrow - Reply Share
Past 24 Hours: 23
Past 7 Days: 135
Past 30 Days: 572
All Time: 93,474
