MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement
Views: 254K
View statistics:
Past 24 Hours:
20
Past 7 Days:
136
Past 30 Days:
637
All Time:
254,277
Comments: 201
143 comments on steps, 58 guide comments.
Go to guide comments
Completed: 162
162 people have marked this guide "completed." Will you be next?
Favorites: 35
35 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Do you have a cracked screen or see weird vertical lines? Fear not! Use this guide to remove/replace the display assembly if something terrible has happened to the beautiful Retina display of your MacBook Pro.
Parts
Tools
    1. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.1 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 2, image 2 of 2
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 3, image 3 of 3
      • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
      • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, Battery Connector: step 4, image 1 of 1
      • Peel back the sticker covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 5, image 3 of 3
      • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
      • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, AirPort/Camera Cables: step 6, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, AirPort/Camera Cables: step 6, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, AirPort/Camera Cables: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
      • The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable.
      • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 7, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 7, image 2 of 2
      • Peel the right rubber cover up off the fan and fold it out of the way.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 8, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 8, image 2 of 2
      • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
      • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 9, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 9, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 9, image 3 of 3
      • Use your fingers to pull the AirPort/Camera cables up off the fan.
      • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
      • Carefully de-route the cables from the plastic cable guide.
      • On reassembly, there should be enough adhesive still on these cables to stick them back down to the fan.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, Display Assembly: step 10, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, Display Assembly: step 10, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement, Display Assembly: step 10, image 3 of 3
      • Use the tip of a spudger to flip up the display data cable lock and rotate it toward the MagSafe 2 power port side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      • Do not touch the contacts on the data connector or its socket with your fingers or any tools, as you may deposit oils or damage the pins.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 11, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 11, image 2 of 2
      • Remove the two rubber hinge covers.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 12, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 12, image 2 of 2
      • Remove the two 3.2 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 13, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 13, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 13, image 3 of 3
      • Remove the two aluminum hinge covers from the MacBook Pro.
      Ask FixBot
    5. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 14, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 14, image 2 of 2
      • Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
      • Leave the innermost screws (one from each hinge) in place.
      • When reassembling, be sure the two screws going back into the hinge on the left go back through the webcam/AirPort cable bracket.
      Ask FixBot
    6. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 15, image 1 of 1
      • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
      Ask FixBot
    7. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 16, image 1 of 1
      • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower (closer to the table) display bracket.
      Ask FixBot
    8. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 17, image 1 of 1
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
      Ask FixBot
    9. MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 18, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 18, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement: step 18, image 3 of 3
      • Grip both halves of the device, one in each hand.
      • Gently push forward on the bottom half of the device to detach it from the display assembly.
      • Carefully set each component aside, making sure to set down the bottom half keyboard-side down to avoid damaging internal components.
      • Replacement displays may not have their hinges adjusted to the correct angle. Use needle nose pliers to gently adjust them to match the hinges on the display being replaced.
      Ask FixBot
162 other people completed this guide.
Andrew Optimus Goldheart
516,014 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
58 Guide Comments
Can the clutch be replaced in the 2015 15" Retina MacBook Pro?
Thomas Taggart - Reply Share
Successfully replaced screen and everything is working great. One mechanical exception - the black clutch cover is loose on one side (the left side looking at the keyboard). i can "lift it" towards myself. it wasn't obvious while i was in there that there was a step to "hook it" into anything. what has it let go from and how do i go about ensuring that it's secure when it's flipped? Anyone know?
Thnaks!
J Allard - Reply Share
It was a perfect job! Thanks!
Mike Mell - Reply Share
Thank you! These instructions couldn't be better.
Devin Fredericks - Reply Share
Do you have any intention of releasing a guide for the new A1707 2016 pro retina model with touch bar? Thanks for your help.
Michael Moore - Reply Share
Past 24 Hours: 20
Past 7 Days: 136
Past 30 Days: 637
All Time: 254,277
