MacBook Pro 15" Retina Display Mid 2012 SSD Replacement
    1. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 2, image 1 of 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement, Battery Connector: step 3, image 1 of 1
      • Peel back the warning label covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 4, image 2 of 2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement, SSD: step 5, image 1 of 1
      • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 6, image 1 of 1
      • Slightly lift the leftmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
      Ask FixBot
123 other people completed this guide.
Jake Devincenzi
119,562 Reputation
57 Guides authored
20 Guide Comments
Apple m'a informé que le SSD est soudé dans le rétina. Ce n'est pas notifié dans ce tutoriel...
J'ai un MACBOOK PRO rétina de mi-2012, pouvez-vous m'en dire plus ?
GWENC2964 - Reply Share
Le SSD n'est pas soudé dans le Macbook Pro 2012 Retina.
urault - Reply Share
Hello,
Thank you for this tutorial.
But can you tell me more information for the SSD?
What's the connexion? It's a M2 SSD or a SSD Sata 3?
Thank for your help.
Daniel Pierard - Reply Share
Hi Daniel, I have the same question. Did you get an answer yet, M.2 SSD or SSD SATA?
I have an SSD from MacBook Pro 15" Retina Display Mid 2012, and now, I'm using a newer model of MacBook Pro.
I'm trying to recover my data o that SSD and have been trying to find the SSD to USB adapter/converter online but haven't found a fit.
I also posted my question here: https://discussions.apple.com/message/31...
Can you help?
Thanks,
Da Cheng Liu - Reply Share
Hi, I followed your guide and changed the ssd to 1Tb.
But when I turn on the laptop, i get the folder with question mark. If I hold Option key while turning on, I get internet renewal option but once trying to run it, the disk is not found. Please help me with this issue fixing. Thanks. Andrej
Andrej - Reply Share
Past 24 Hours: 13
Past 7 Days: 118
Past 30 Days: 557
All Time: 360,105
