MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement
    1. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement: step 2, image 1 of 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, Battery Connector: step 3, image 1 of 1
      • Peel back the warning label covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement: step 4, image 2 of 2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 5, image 3 of 3
      • Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
      • In a similar fashion, remove the I/O board cable from its socket on the I/O board.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement: step 6, image 1 of 1
      • Remove the I/O board cable from the MacBook Pro.
      Ask FixBot
12 other people completed this guide.
Brett Hartt
132,329 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
83,560 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 58
All Time: 9,752
