MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement
    1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 2, image 1 of 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Battery Connector: step 3, image 1 of 1
      • Peel back the warning label covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 4, image 2 of 2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: step 5, image 3 of 3
      • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
      • Slide the spudger underneath the length of the cover, releasing the adhesive.
      • Lift the cover and rotate it off of the heat sink.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 6, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 6, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 6, image 3 of 3
      • In the same manner described above, release the adhesive and flip back the heat sink cover on the left fan.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 7, image 1 of 1
      • Remove the following ten screws securing the heat sink to the logic board:
      • Two 2.4 mm T5 Torx screws
      • Six 3.4 mm T5 Torx screws
      • One 5.2 mm Raised Head T5 Torx screw
      • One 3.5 mm T5 Torx screw
      Ask FixBot
    4. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: step 8, image 1 of 1
      • Grasping the heat sink from one side, lift the heat sink off of the MacBook Pro, pulling it free from the computer.
      • The thermal paste may make it difficult to remove the heat sink. Pull the heat sink off gently but forcefully to avoid damaging any components on the logic board.
      • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See our Applying Thermal Paste guide for further instructions.
      Ask FixBot
41 other people completed this guide.
Brett Hartt
132,500 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
8 Guide Comments
would doing this void the warranty?
sakada - Reply Share
Hello everybody!!! I tried to follow this guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torn screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
Shaggot96 - Reply Share
I'm sorry to hear that! Try checking out this stripped screw guide and reading through this Answers post. Hope this helps with your repair!
Sam Goldheart - Reply Share
I won't call this moderate but rather easy instead, seems like ifixit expect that easy is something you just unplug without even open the computer
Benjamin H - Reply Share
Where can I get new screws if I want to replace them?
Boro J. - Reply Share
Past 24 Hours: 12
Past 7 Days: 55
Past 30 Days: 209
All Time: 46,343
