MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement
    1. MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement: step 2, image 1 of 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement, Battery Connector: step 3, image 1 of 1
      • Peel back the warning label covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement: step 4, image 2 of 2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement, AirPort Board: step 5, image 1 of 1
      • Use the tip of a spudger to detach the three antenna connectors up from their sockets on the AirPort board.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement: step 6, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 AirPort Board Replacement: step 6, image 2 of 2
      • Remove the single 2.9 mm T5 Torx screw securing the AirPort board to the logic board.
      • Grasp the edges of the board and slide it out from its connector.
      • Lift and remove the AirPort board.
      Ask FixBot
34 other people completed this guide.
Jake Devincenzi
119,437 Reputation
57 Guides authored
12 Guide Comments
Is the new AirPort AC card for the 2013 MacBook Pro Retina interchangeable? In other words, can I now upgrade to the new AirPort?
rbouch8828 - Reply Share
Yes, it works. I just bought an AirPort AC board from the late 2013 RMBP and installed in my mid 2012 model, and it works perfectly. Highly recommended upgrade.
Frederico - Reply Share
Frederico, can you please share which part number you used to upgrade?
Thank you,
Jose
estradajoe - Reply Share
Frederico, what was the part number for the ac card you bought and used. I'm interested in getting one as well.
Buggy - Reply Share
Anyone has an idea, what size the card actually has? Is it a full-size or half-size mini-pci-e? Looks like full-size. I am only running linux on my macbook and the broadcom drivers are really bad, so I would like to change it and I only find official airport boards on the internet.
Victor Brekenfeld - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 86
All Time: 68,920
