MacBook Pro 15" Retina Display Early 2013 SSD Replacement
    1. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Ask FixBot
    2. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: step 2, image 1 of 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Battery Connector: step 3, image 1 of 1
      • Peel back the warning label covering the battery connector.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: step 4, image 2 of 2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Ask FixBot
    1. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, SSD: step 5, image 1 of 1
      • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: step 6, image 1 of 2 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: step 6, image 2 of 2
      • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
      Ask FixBot
60 other people completed this guide.
Sam Goldheart
477,959 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,442 Guides authored
17 Guide Comments
Where is the left fan in the pic? Please tell me I don't need to remove the fan before doing the replacement.
Ethan - Reply Share
I see that for all the guides for all the MBP models with solid state storage, the battery is disconnected before the solid state storage is removed. Why?
Traditional hard drives and SSDs don't have to have their batteries disconnected before removing...do they?
Hobowan Kenobi - Reply Share
You should remove it. It's just good practice when doing anything internal on any laptop.
farleyaustin - Reply Share
这个ssd的接口是什么呢?我应该购买什么型号的ssd能适配这个,怎么筛选?
lizhao - Reply Share
Can I update my SSD to 1TB from 512GB? RMBP 2013 Early
FAN Guoxing - Reply Share
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 148
All Time: 109,666
