MacBook Pro 14" 2025 (M5) Lower Case Replacement
    1. MacBook Pro 14" 2025 (M5) Lower Case Replacement, Unfasten the lower case: step 1, image 1 of 1
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a P5 pentalobe driver to remove the eight screws securing the lower case:
      • Four 9.2 mm-long screws along the back edge (near the screen hinge)
      • Four 5 mm-long screws along the front edge (near the trackpad)
      Ask FixBot
    2. MacBook Pro 14" 2025 (M5) Lower Case Replacement, Release the sliding clips: step 2, image 1 of 3 MacBook Pro 14" 2025 (M5) Lower Case Replacement, Release the sliding clips: step 2, image 2 of 3 MacBook Pro 14" 2025 (M5) Lower Case Replacement, Release the sliding clips: step 2, image 3 of 3
      • Sliding clips along the back edge of the MacBook secure the lower case. In this step, you'll shift the lower case away from the hinges to free it from these clips.
      • Insert the flat end of a spudger between the lower case and the right screen hinge.
      • Lever your spudger against the hinge to push the lower case away from it.
      • Repeat for the left hinge.
      Ask FixBot
    3. MacBook Pro 14" 2025 (M5) Lower Case Replacement, Lower case information: step 3, image 1 of 1
      • After you've released the sliding clips along the back edge, four remaining clips secure the lower case to the frame:
      • Two clips near the cutouts in the frame
      • Two clips near the middle of the lower case
      • As you release the lower case from the frame, you'll hear and feel a distinct "pop" as each of these four clips release.
      Ask FixBot
    4. MacBook Pro 14" 2025 (M5) Lower Case Replacement, Release the right clips: step 4, image 1 of 3 MacBook Pro 14" 2025 (M5) Lower Case Replacement, Release the right clips: step 4, image 2 of 3 MacBook Pro 14" 2025 (M5) Lower Case Replacement, Release the right clips: step 4, image 3 of 3
      • Don't insert your tool deeper than 1 cm (a little less than half an inch) near the front of the speaker cutouts to avoid damaging the speakers.
      • Insert the flat end of your spudger into the front of the cutout in the right side of the frame.
      • Slide your spudger toward the back of the cutout and pry up to release the two right-side clips.
      • Repeat for the left-side speaker cutout to release the two left-side clips.
      Ask FixBot
    5. MacBook Pro 14" 2025 (M5) Lower Case Replacement, Remove the lower case: step 5, image 1 of 3 MacBook Pro 14" 2025 (M5) Lower Case Replacement, Remove the lower case: step 5, image 2 of 3 MacBook Pro 14" 2025 (M5) Lower Case Replacement, Remove the lower case: step 5, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
      • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
      • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
      • You'll hear and feel each clip snap into place.
      Ask FixBot
Spencer Day
201,702 Reputation
1,244 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 55
Past 30 Days: 214
All Time: 410
