MacBook Pro 14" 2023 Headphone Jack Replacement
    1. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the lower case: step 1, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the lower case: step 1, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
      • Four 9.3 mm screws
      • Four 5 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 14" 2023 Headphone Jack Replacement, Unclip the lower case: step 2, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Unclip the lower case: step 2, image 2 of 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle to create a small gap under the lower case.
      Ask FixBot
    3. MacBook Pro 14" 2023 Headphone Jack Replacement, Release the right clips: step 3, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the right clips: step 3, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the right clips: step 3, image 3 of 3
      • Insert an opening pick into the gap you just created.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 14" 2023 Headphone Jack Replacement, Release the left clips: step 4, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the left clips: step 4, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the left clips: step 4, image 3 of 3
      • Repeat the previous step on the other side, using an opening pick to to release the second clip.
      Ask FixBot
    5. MacBook Pro 14" 2023 Headphone Jack Replacement, Release the sliding clips: step 5, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the sliding clips: step 5, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the sliding clips: step 5, image 3 of 3
      • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
      • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
      • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
      Ask FixBot
    6. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the lower case: step 6, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the lower case: step 6, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the lower case: step 6, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
      • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
      • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
      • You'll hear and feel each clip snap into place.
      Ask FixBot
    1. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery board: step 7, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery board: step 7, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery board: step 7, image 3 of 3
      • Peel back any tape covering the battery board data cable connector on the logic board.
      Ask FixBot
    2. MacBook Pro 14" 2023 Headphone Jack Replacement: step 8, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 8, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Ask FixBot
    3. MacBook Pro 14" 2023 Headphone Jack Replacement: step 9, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 9, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
      Ask FixBot
    4. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the trackpad cable bracket: step 10, image 1 of 1
      • Use a 3IP Torx Plus driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
      Ask FixBot
    5. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the trackpad cable bracket: step 11, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the trackpad cable bracket: step 11, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the trackpad cable bracket.
      Ask FixBot
    6. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the trackpad cable: step 12, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the trackpad cable: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. MacBook Pro 14" 2023 Headphone Jack Replacement, Reposition the trackpad cable: step 13, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Reposition the trackpad cable: step 13, image 2 of 2
      • The trackpad cable is lightly adhered to the frame.
      • Peel the trackpad cable away from the device, making sure to separate the adhesive.
      Ask FixBot
    8. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery board: step 14, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery board: step 14, image 2 of 2
      • Peel back any tape covering the battery board data cable connector under the large pancake screw.
      Ask FixBot
    9. MacBook Pro 14" 2023 Headphone Jack Replacement: step 15, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 15, image 2 of 2
      Ask FixBot
    10. MacBook Pro 14" 2023 Headphone Jack Replacement: step 16, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 16, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
      Ask FixBot
    11. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the data cable: step 17, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the data cable: step 17, image 2 of 2
      • The battery board data cable is lightly adhered to the device.
      • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
      • Remove the battery board data cable.
      Ask FixBot
    12. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the battery connector: step 18, image 1 of 1
      • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
      Ask FixBot
    13. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery connector: step 19, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery connector: step 19, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the battery connector: step 19, image 3 of 3
      • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
      • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
      • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
      Ask FixBot
    1. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the antenna bar's connector bracket: step 20, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the antenna bar's connector bracket: step 20, image 2 of 2
      • Use a 3IP Torx Plus screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
      Ask FixBot
    2. MacBook Pro 14" 2023 Headphone Jack Replacement: step 21, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 21, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
      Ask FixBot
    3. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the antenna bar: step 22, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the antenna bar: step 22, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
      • Repeat for the two other cables.
      • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
      Ask FixBot
    4. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the screen cable covers: step 23, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the screen cable covers: step 23, image 2 of 2
      • Use a 3IP Torx Plus driver to remove the four 2.1 mm screws securing the screen cable covers.
      Ask FixBot
    5. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the screen cable covers: step 24, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the screen cable covers: step 24, image 2 of 2
      • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
      Ask FixBot
    6. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the screen cables: step 25, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the screen cables: step 25, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the screen cables: step 25, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
      Ask FixBot
    7. MacBook Pro 14" 2023 Headphone Jack Replacement: step 26, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 26, image 2 of 2
      • Repeat the previous disconnection process for the remaining press connector at the top left of the logic board.
      • Don't pry against the surface-mounted components near the press connector.
      Ask FixBot
    8. MacBook Pro 14" 2023 Headphone Jack Replacement: step 27, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 27, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 27, image 3 of 3
      • Peel back any tape covering the microphone cable connector.
      Ask FixBot
    9. MacBook Pro 14" 2023 Headphone Jack Replacement: step 28, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 28, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
      Ask FixBot
    10. MacBook Pro 14" 2023 Headphone Jack Replacement: step 29, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 29, image 2 of 2
      • Disconnect the microphone cable by sliding it out from its socket on the logic board.
      Ask FixBot
    11. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the right-side cable covers: step 30, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the right-side cable covers: step 30, image 2 of 2
      • Use a 3IP Torx Plus driver to remove the nine 2.1 mm screws securing the right cable covers to the frame:
      Ask FixBot
    12. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the right cable covers: step 31, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the right cable covers: step 31, image 2 of 2
      • Use tweezers, or your fingers, to remove the five right cable covers.
      Ask FixBot
    13. MacBook Pro 14" 2023 Headphone Jack Replacement: step 32, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 32, image 2 of 2
      • Peel back any tape covering the right speaker cable.
      Ask FixBot
    14. MacBook Pro 14" 2023 Headphone Jack Replacement: step 33, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 33, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the right speaker cable.
      Ask FixBot
    15. MacBook Pro 14" 2023 Headphone Jack Replacement: step 34, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 34, image 2 of 2
      • Disconnect the right speaker cable by sliding it out from its socket on the logic board.
      Ask FixBot
    16. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the headphone jack: step 35, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the headphone jack: step 35, image 2 of 2
      • Use a spudger to pry up and disconnect the headphone jack's press connector.
      Ask FixBot
    17. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the right USB-C ports: step 36, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the right USB-C ports: step 36, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the right USB-C ports: step 36, image 3 of 3
      • Use a spudger to pry up and disconnect the right USB-C ports' press connectors.
      Ask FixBot
    18. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the MagSafe port: step 37, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the MagSafe port: step 37, image 2 of 2
      • Use a spudger to pry up and disconnect the MagSafe port's press connector.
      Ask FixBot
    19. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the lid angle sensor cable: step 38, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the lid angle sensor cable: step 38, image 2 of 2
      • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
      Ask FixBot
    20. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the left cable covers: step 39, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the left cable covers: step 39, image 2 of 2
      • Use a 3IP Torx Plus driver to remove the four screws securing the left cable covers to the frame:
      • Two 2 mm screws
      • Two 2.1 mm screw
      Ask FixBot
    21. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the left cable covers: step 40, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the left cable covers: step 40, image 2 of 2
      • Use tweezers, or your fingers, to remove the two left cable covers.
      Ask FixBot
    22. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the left speaker: step 41, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the left speaker: step 41, image 2 of 2
      • Peel back any tape covering the left speaker cable.
      Ask FixBot
    23. MacBook Pro 14" 2023 Headphone Jack Replacement: step 42, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 42, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the left speaker cable.
      Ask FixBot
    24. MacBook Pro 14" 2023 Headphone Jack Replacement: step 43, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 43, image 2 of 2
      • Disconnect the left speaker cable by sliding it out from its socket on the logic board.
      Ask FixBot
    25. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the left USB-C port: step 44, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the left USB-C port: step 44, image 2 of 2
      • Use a spudger to pry up and disconnect the left USB-C port's press connector.
      Ask FixBot
    26. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the Touch ID sensor: step 45, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the Touch ID sensor: step 45, image 2 of 2
      • Use a spudger to pry up and disconnect the Touch ID sensor's press connector near the top left of the device.
      • The Touch ID sensor cable is adhered to the frame. If the adhesive doesn't separate when you disconnect the press connector, slide an opening pick under the cable to separate it.
      Ask FixBot
    27. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the keyboard: step 46, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the keyboard: step 46, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the keyboard: step 46, image 3 of 3
      Ask FixBot
    28. MacBook Pro 14" 2023 Headphone Jack Replacement: step 47, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 47, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 47, image 3 of 3
      • Use a spudger to gently pry up the locking flap on the ZIF connectors for the keyboard cables.
      Ask FixBot
    29. MacBook Pro 14" 2023 Headphone Jack Replacement: step 48, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 48, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 48, image 3 of 3
      • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
      Ask FixBot
    30. MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the fans: step 49, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the fans: step 49, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Disconnect the fans: step 49, image 3 of 3
      • Peel back any tape covering the right fan cable connector.
      Ask FixBot
    31. MacBook Pro 14" 2023 Headphone Jack Replacement: step 50, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 50, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
      Ask FixBot
    32. MacBook Pro 14" 2023 Headphone Jack Replacement: step 51, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 51, image 2 of 2
      • Disconnect the right fan cable by sliding it out from its socket on the logic board.
      Ask FixBot
    33. MacBook Pro 14" 2023 Headphone Jack Replacement, Reposition the right fan cable: step 52, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Reposition the right fan cable: step 52, image 2 of 2
      • The right fan cable is lightly adhered to the logic board.
      • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
      • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
      Ask FixBot
    34. MacBook Pro 14" 2023 Headphone Jack Replacement: step 53, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 53, image 2 of 2
      • Repeat the previous disconnection and reposition procedure for the left fan.
      Ask FixBot
    35. MacBook Pro 14" 2023 Headphone Jack Replacement: step 54, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 54, image 2 of 2
      • Remove the four black screw covers from the logic board.
      Ask FixBot
    36. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the logic board: step 55, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the logic board: step 55, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the logic board: step 55, image 3 of 3
      • Use a T5 Torx driver to remove the 11 screws securing the logic board:
      • Four 3.6 mm screws
      • Two 4.5 mm screws
      • Two 5.2 mm screws
      • Two 3.8 mm screws
      • One 3.9 mm screw
      Ask FixBot
    37. MacBook Pro 14" 2023 Headphone Jack Replacement: step 56, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 56, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement: step 56, image 3 of 3
      • Use a T6 Torx driver to remove the three screws securing the logic board:
      • Two 4.7 mm screws
      • One 5.7 mm screw
      Ask FixBot
    38. MacBook Pro 14" 2023 Headphone Jack Replacement, Release the logic board's clips: step 57, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Release the logic board's clips: step 57, image 2 of 2
      • Insert a spudger between the right side of the logic board and the frame.
      • Pry up with the spudger to release the logic board from its clips.
      Ask FixBot
    39. MacBook Pro 14" 2023 Headphone Jack Replacement: step 58, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement: step 58, image 2 of 2
      • Insert a spudger between the bottom of the logic board and the frame.
      Ask FixBot
    40. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the logic board: step 59, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the logic board: step 59, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the logic board: step 59, image 3 of 3
      • Gently lift up the logic board by its right side to release it from its alignment pegs.
      • If it feels like it's not coming out, check that all the cables are disconnected.
      • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
      • Remove the logic board.
      Ask FixBot
    41. MacBook Pro 14" 2023 Headphone Jack Replacement, Reassembly information: step 60, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Reassembly information: step 60, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Reassembly information: step 60, image 3 of 3
      • During reassembly, perform the following:
      • Make sure all 18 connectors are above the logic board before securing it back into the frame.
      • If you're having trouble positioning the connectors, use tape to keep them out of the way.
      • Hold the rubber spacers out of the way so the fins can drop into their recesses.
      • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
      • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
      Ask FixBot
    1. MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the headphone jack: step 61, image 1 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the headphone jack: step 61, image 2 of 3 MacBook Pro 14" 2023 Headphone Jack Replacement, Unfasten the headphone jack: step 61, image 3 of 3
      • Use a T5 Torx driver to remove the two screws securing the headphone jack:
      • One 3.5 mm screw
      • One 5.6 mm screw
      Ask FixBot
    2. MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the headphone jack: step 62, image 1 of 2 MacBook Pro 14" 2023 Headphone Jack Replacement, Remove the headphone jack: step 62, image 2 of 2
      • Use your fingers to remove the headphone jack.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
Chayton Ritter
27,465 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,150 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 36
All Time: 1,139
