MacBook Pro 14" 2021 Speakers Replacement
    1. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the lower case: step 1, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Unfasten the lower case: step 1, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
      • Four 9.3 mm screws
      • Four 5 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 14" 2021 Speakers Replacement, Unclip the lower case: step 2, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Unclip the lower case: step 2, image 2 of 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle to create a small gap under the lower case.
      Ask FixBot
    3. MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: step 3, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: step 3, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: step 3, image 3 of 3
      • Insert an opening pick into the gap you just created.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: step 4, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: step 4, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: step 4, image 3 of 3
      • Repeat the previous step on the other side, using an opening pick to to release the second clip.
      Ask FixBot
    5. MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: step 5, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: step 5, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: step 5, image 3 of 3
      • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
      • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
      • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
      Ask FixBot
    6. MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: step 6, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: step 6, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: step 6, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
      • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
      • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
      • You'll hear and feel each clip snap into place.
      Ask FixBot
    1. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: step 7, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: step 7, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: step 7, image 3 of 3
      • Peel back any tape covering the battery board data cable connector on the logic board.
      Ask FixBot
    2. MacBook Pro 14" 2021 Speakers Replacement: step 8, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 8, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Ask FixBot
    3. MacBook Pro 14" 2021 Speakers Replacement: step 9, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 9, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
      Ask FixBot
    4. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the trackpad cable bracket: step 10, image 1 of 1
      • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
      Ask FixBot
    5. MacBook Pro 14" 2021 Speakers Replacement, Remove the trackpad cable bracket: step 11, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Remove the trackpad cable bracket: step 11, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the trackpad cable bracket.
      Ask FixBot
    6. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the trackpad cable: step 12, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the trackpad cable: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. MacBook Pro 14" 2021 Speakers Replacement, Reposition the trackpad cable: step 13, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Reposition the trackpad cable: step 13, image 2 of 2
      • The trackpad cable is lightly adhered to the frame.
      • Peel the trackpad cable away from the device, making sure to separate the adhesive.
      Ask FixBot
    8. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: step 14, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: step 14, image 2 of 2
      • Peel back any tape covering the battery board data cable connector under the large pancake screw.
      Ask FixBot
    9. MacBook Pro 14" 2021 Speakers Replacement: step 15, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 15, image 2 of 2
      Ask FixBot
    10. MacBook Pro 14" 2021 Speakers Replacement: step 16, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 16, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
      Ask FixBot
    11. MacBook Pro 14" 2021 Speakers Replacement, Remove the data cable: step 17, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Remove the data cable: step 17, image 2 of 2
      • The battery board data cable is lightly adhered to the device.
      • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
      • Remove the battery board data cable.
      Ask FixBot
    12. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the battery connector: step 18, image 1 of 1
      • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
      Ask FixBot
    13. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: step 19, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: step 19, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: step 19, image 3 of 3
      • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
      • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
      • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
      Ask FixBot
    1. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the right speaker: step 20, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the right speaker: step 20, image 2 of 2
      • Peel back the tape covering the right speaker ZIF connector.
      Ask FixBot
    2. MacBook Pro 14" 2021 Speakers Replacement: step 21, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 21, image 2 of 2
      • Use the pointed end of a spudger to gently pry up the locking flap on the right speaker ZIF connector.
      Ask FixBot
    3. MacBook Pro 14" 2021 Speakers Replacement: step 22, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 22, image 2 of 2
      • Disconnect the right speaker cable by sliding it out from its socket.
      Ask FixBot
    4. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: step 23, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: step 23, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: step 23, image 3 of 3
      • Follow the procedure in the previous three steps to disconnect the left speaker.
      Ask FixBot
    5. MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: step 24, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: step 24, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: step 24, image 3 of 3
      • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) in the gap between the speaker and the edge of the frame.
      • Wait for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
      Ask FixBot
    6. MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: step 25, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: step 25, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: step 25, image 3 of 3
      • Insert the tip of an opening pick in the gap between the speaker and the edge of the frame.
      • Slide the opening pick along the edge of the speaker to slice the adhesive beneath it.
      Ask FixBot
    7. MacBook Pro 14" 2021 Speakers Replacement: step 26, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 26, image 2 of 2
      • Insert the tip of an opening pick in the gap between the battery and the speaker.
      • Pry up with the pick to separate the speaker from the frame.
      • Take care not to puncture the battery while you pry. If you're having difficulty prying up, apply a few more drops of isopropyl alcohol.
      Ask FixBot
    8. MacBook Pro 14" 2021 Speakers Replacement: step 27, image 1 of 2 MacBook Pro 14" 2021 Speakers Replacement: step 27, image 2 of 2
      • Slide the pick along the edge of the speaker to separate the adhesive.
      Ask FixBot
    9. MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: step 28, image 1 of 3 MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: step 28, image 2 of 3 MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: step 28, image 3 of 3
      Tesa 61395 Tape
      $8.95
      Buy
      • Use your fingers to remove the speaker, making sure to peel off any remaining adhesive.
      • Repeat the loosening and separating process for the other speaker.
      • Use a pre-cut adhesive sheet, like Tesa Tape, to secure the speaker back to the frame.
      • Clean up any remaining adhesive from the frame before installing new adhesives.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
6 other people completed this guide.
Alex Diaz-Kokaisl
249,573 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,532 Guides authored
4 Guide Comments
The description up top alludes to having to remove the logic board + fans to replace the speakers, but that doesn't seem to be the case in the step by step. Can anyone who's completed this speaker replacement clear that up?
thardee - Reply Share
Hi thardee, thanks for pointing that out. You're right, the logic board and fans don't need to be removed to replace the speakers. I've removed that section from the description.
Chayton Ritter - Reply Share
Can you be clear about what is considered the right speaker? From the images, it appears you are removing the left speaker, as it appears when using the laptop in normal orientation. Obviously, with the base removed and the batteries at the bottom, this will be on the right when working on the laptop. If I were to order a replacement for what I consider to be the right speaker (i.e. the one by my right hand when typing), what should I specify (or do they only come in pairs anyway)?
Tim Holmes - Reply Share
Be careful to not use too much force when removing the old speakers. When I opened the MacBook after the repair, a couple of keycaps were loose and fell off (caps lock and enter).
It seems some tiny plastic hooks were damaged. Not sure if this was due to force or the iso alcohol.
Oliver Nelson - Reply Share
Past 24 Hours: 11
Past 7 Days: 105
Past 30 Days: 364
All Time: 15,916
