Up to 20% off select tools
MacBook Pro 13" Unibody Mid 2012 RAM Replacement
Views: 440K
View statistics:
Past 24 Hours:
29
Past 7 Days:
150
Past 30 Days:
694
All Time:
440,307
Comments: 102
52 comments on steps, 50 guide comments.
Go to guide comments
Completed: 614
614 people have marked this guide "completed." Will you be next?
Favorites: 222
222 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Upgrade the RAM in your Mid 2012 MacBook Pro 13" Unibody.
    1. MacBook Pro 13" Unibody Mid 2012 RAM Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following ten screws:
      • Three 14.4 mm Phillips #00 screws
      • Three 3.5 mm Phillips #00 screws
      • Four 3.5 mm shouldered Phillips #00 screws
      • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2012 RAM Replacement: step 2, image 1 of 2 MacBook Pro 13" Unibody Mid 2012 RAM Replacement: step 2, image 2 of 2
      • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
      • Remove the lower case.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2012 RAM Replacement, Battery Connection: step 3, image 1 of 2 MacBook Pro 13" Unibody Mid 2012 RAM Replacement, Battery Connection: step 3, image 2 of 2
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2012 RAM Replacement: step 4, image 1 of 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2012 RAM Replacement, RAM: step 5, image 1 of 2 MacBook Pro 13" Unibody Mid 2012 RAM Replacement, RAM: step 5, image 2 of 2
      • Pull the two RAM retaining arms away from the center of the RAM chip.
      • The RAM chip should "pop" up slightly from its socket.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2012 RAM Replacement: step 6, image 1 of 1
      • Pull the RAM stick out of its socket.
      • Repeat this process to remove the second RAM chip.
      Ask FixBot
614 other people completed this guide.
Author
with
Andrew Optimus Goldheart
516,617 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
50 Guide Comments
My mid-2012 2.5 i5 works perfectly with 16 Gb of 1600Mhz DDR3.
nix - Reply Share
Just replaced my 4GB with 16GB of PNY from Best Buy. AWESOME difference in performance!!
Michael Chandler - Reply Share
Could you please specify the memory chip that you bought? I need more details in order to get the right one, thanks!
Lin - Reply Share
Any memory kit that is either validated by Apple or that has the proper channel configuration (9-9-9-24) is okay to use. If you are looking for pure performance RAM, a kit of Corsair Vengeance RAM is okay to use (again, check the channel configuration), but most people will benefit from a kit of Corsair Mac Memory or the kit that iFixit provides in the volume of your choice.
Seji the veggie - Reply Share
Past 24 Hours: 29
Past 7 Days: 150
Past 30 Days: 694
All Time: 440,307
