MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement
    1. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement, Remove the lower case screws: step 1, image 1 of 1
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement, Lift the lower case away: step 2, image 1 of 1
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement, Battery: step 3, image 1 of 1
      • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
      • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement, Hard Drive: step 4, image 1 of 1
      • Remove two Phillips screws securing the hard drive bracket to the upper case.
      • These screws are captive to the hard drive bracket.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 5, image 1 of 1
      • Lift the retaining bracket out of the upper case.
      Ask FixBot
    3. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 6, image 1 of 1
      • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
      Ask FixBot
    4. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 7, image 1 of 1
      • Remove the hard drive cable by pulling its connector straight away from the hard drive.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement, Hard Drive Cable: step 8, image 1 of 1
      • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
      • Two 1.5 mm Phillips screws.
      • Two 9.5 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 9, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 9, image 2 of 2
      • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
      • Carefully peel the hard drive and IR sensor cable from the upper case.
      Ask FixBot
    3. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 10, image 1 of 1
      • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
      Ask FixBot
    4. MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement: step 11, image 1 of 1
      • Lift the hard drive/IR sensor cable assembly out of the upper case.
      • If your replacement part does not come with the hard drive bracket and indicator light, you will need to pull those off of the part you are removing and install them on the new part.
      • Your replacement part may come with several adhesive foam bumpers. These are to ensure a snug fit of both bracket and hard drive. Apply only as needed.
      Ask FixBot
211 other people completed this guide.
6 Guide Comments
Fantiastic!!
I had an SSD installed but it stopped working after a few months and I got the flashing question mark folder. It was very odd as the disk drive still worked, and the SSD did externally. Heard it could be the SATA as SSDs are more sensitive to damaged cables, so replaced it on the off chance and it worked! Definitely recommend trying this first if you have had the same problem
AC1 - Reply Share
Wow, this worked so GOOD! ...and those derps at the local Apple retailer told me to "let the computer go, and take a look at the new ones we have here!"
Did troubleshooting with ifixit, ordered part from ifixit and followed step-by-step guide provided by ifixit! You guys rule!
Many thanks from Sweden!
Mikael Parkman - Reply Share
This worked like a charm. My mid 2010 MacBook Pro is back. Although it was temping to claim my Mac as dead and buy the latest baddest MacBook, I had to try a $50 fix. It worked. I saved over $1200 now. I want to see how long my 2010 Mac lasts now. Thanks ifixit.com.
David Cantu - Reply Share
This went very smoothly. I had already tried replacing the hard drive, so there were only a few new steps for me. Glad I didn't have to take apart the bracket and light in the last step. Time machine is chugging away as I speak, and my 2010 is not on the scrap heap just yet.
David Haye - Reply Share
This is the second time this cable has failed in this machine (Apple fixed it once for free). Seeing the FIVE right-angle bends the cable makes to get from the disk to the motherboard connector makes it clear why this part fails. Being able to buy this cable from iFixit and follow the step-by-step guide is GREAT--since Apple refuses to touch machines after they are five years old.
One hint for reassembly: first pin the cable down with the four screws, then attach the motherboard connection, then use something to temporarily hold the disk connector/cable out of the way, then pre-place the sensor/light cable against the case so you know where you want it to go, then cheat the paper glue cover off of the sensor/light cable as you smooth it against the case. Then the disk connector goes onto the disk, the disk seats easily, and then the retaining bracket is trivial.
Removing the sensor/light/disk-seat from the case was a little fiddly. It feels "stuck" because the cable is GLUED to the case!
David Eckhardt - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 124
All Time: 119,406
