MacBook Pro 13" Unibody Mid 2010 Display Replacement
    1. MacBook Pro 13" Unibody Mid 2010 Display Replacement, Remove the lower case screws: step 1, image 1 of 1
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Display Replacement, Lift the lower case away: step 2, image 1 of 1
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Display Replacement, Battery: step 3, image 1 of 1
      • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
      • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
      Ask FixBot
    1. MacBook Pro 13" Unibody Mid 2010 Display Replacement, Display: step 4, image 1 of 1
      • Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
      • Pry up from beneath the wires.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 5, image 1 of 1
      • Disconnect the camera cable by pulling the male end straight away from its socket.
      • Make sure to pull the connector parallel to the face of the logic board and toward the optical drive, not straight up from its socket.
      Ask FixBot
    3. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 6, image 1 of 1
      • De-route the camera data cable from the channel in the optical drive.
      Ask FixBot
    4. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 7, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 7, image 2 of 2
      • Remove the following screws:
      • Two 10 mm Phillips screws
      • One 3.8 mm Phillips screw
      • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
      Ask FixBot
    5. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 8, image 1 of 3 MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 8, image 2 of 3 MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 8, image 3 of 3
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable connector straight away from its socket.
      • Make sure to pull the connector straight away and not straight up from its socket.
      Ask FixBot
    6. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 9, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 9, image 2 of 2
      • Remove the following two screws securing the display data cable bracket to the upper case:
      • One 8.6 mm Phillips screw
      • One 5.6 mm Phillips screw
      • Lift the display data cable bracket out of the upper case.
      Ask FixBot
    7. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 10, image 1 of 1
      • If present, remove the small strip of foam tape stuck to the display screws near the display data cable.
      Ask FixBot
    8. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 11, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 11, image 2 of 2
      • Remove the two outer 6.5 mm T8 Torx screws securing each of the two display brackets to the upper case (4 screws total).
      Ask FixBot
    9. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 12, image 1 of 1
      • Open your MacBook so the display is perpendicular to the upper case.
      • Place your opened MacBook on a table as pictured.
      • While holding the display and upper case together with your left hand, remove the remaining 6.5 mm T8 Torx screw from the lower display bracket.
      Ask FixBot
    10. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 13, image 1 of 1
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • Remove the last remaining T8 Torx screw securing the display to the upper case.
      Ask FixBot
    11. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 14, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 14, image 2 of 2
      • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
      • Rotate the display slightly away from the upper case.
      Ask FixBot
    12. MacBook Pro 13" Unibody Mid 2010 Display Replacement: step 15, image 1 of 1
      • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
      Ask FixBot
78 other people completed this guide.
5 Guide Comments
Awesome guide!! Thank you so much for walking me through this. It was surprisingly easy. Only took me about 30 min to do. Best Buy Canada quoted me $900 to do this repair. Total cost of tools from iFixit and parts from eBay... $280 :) THANK YOU IFIXIT!!!!!
spenczoid - Reply Share
Thanks for the guide, it was spot on. I dropped my beloved MacBook Pro and it cracked the display. Following the guide was a snap even for my old eyes, the ability to make the pictures full screen is great.
jackpollard - Reply Share
I found a used complete display unit for sale on ebay. Delivered 50$ and half an hour of work and am up and have a lovely MBP 13 inch mid 2010. Many thanks for the useful and detailed guide.
keithp198 - Reply Share
Had the standard problem with a loose screen on a MacBook Pro 13in 2010. Followed the guide which is very clear and got to the screws which I could then tighten. Reassembled and on booting could hear the fan but no display aside from a few flashes. Rechecked the screen data cable connection which was slightly mis-aligned. corrected it and it worked fine. That connection is very sensitive!
Saved me $900 quoted by the Macstore - 90 mins work on my own and a few grey hairs. A glass of red wine helps.
Norbert - Reply Share
Just followed the steps and I successfully reinstalled a new screen/lid assembly. The only problem being was step 4. When gently (underline gently) removed the audio cable, all of the pins fractured and remained in the board so now my onboard audio is highly limited. I have to ask why was that step necessary as the removal/reinstall would have been completely possible without step 4. Greg
gdmenginc - Reply Share
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 189
All Time: 89,592
