MacBook Pro 13" Unibody Mid 2009 Lower Case Replacement
    1. MacBook Pro 13" Unibody Mid 2009 Lower Case Replacement, Remove the lower case screws: step 1, image 1 of 1
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. MacBook Pro 13" Unibody Mid 2009 Lower Case Replacement, Lift the lower case away: step 2, image 1 of 1
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      Ask FixBot
53 other people completed this guide.
1 Guide Comment
2 tornillos se da&aron, los q estan al lado de las lenguetas de montaje -lado de la bateria- pues la bateria se inflo y presiona la carcasa
q haces p resolver ??
enrique lopez vega - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 122
All Time: 46,397
