MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement
    1. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Left Speaker: step 7, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Left Speaker: step 7, image 2 of 2
      • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
      • Be careful not to damage any surface-mounted components.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 8, image 1 of 1
      • Remove the following screws securing the left speaker to the upper case:
      • One 5.7 mm T5 Torx screw
      • One 6.5 mm T5 Torx screw
      • One 3.8 mm T5 Torx screw
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 9, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 9, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: step 9, image 3 of 3
      • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
      • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
      Ask FixBot
43 other people completed this guide.
Sam Goldheart
478,418 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
참조해서 잘따라했어요~ 너무 감사해요^___^
권정철 - Reply Share
I love ifixit!
Ian Wainwright - Reply Share
Youhelpme, ifixit. Done! Thx
Caue Rodergas - Reply Share
tnx you for you help ... good job with 30min ifixit
Joeri Van Den Bulck - Reply Share
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 147
All Time: 28,406
