MacBook Pro 13" Retina Display Mid 2014 Fan Replacement
    1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: step 7, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: step 7, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: step 7, image 3 of 3
      • Carefully remove the rubber fan bumper from the edge of the heat sink.
      • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 9, image 1 of 1
      • Remove the following screws securing the heat sink to the logic board:
      • Four 2.6 mm T5 screws
      • One 2.4 mm Phillips #000 screw
      Ask FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 10, image 2 of 2
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: step 11, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: step 11, image 2 of 2
      • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 12, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 12, image 2 of 2
      • Peel the iSight camera cable off the fan housing to fold it out of the way.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 13, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 13, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 13, image 3 of 3
      • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
      • Carefully pull the fan cable straight out of its socket.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 14, image 1 of 1
      • Remove the following screws securing the fan to the upper case:
      • One 5.0 mm T5 Torx screw
      • Two 3.6 mm T5 Torx screws
      Ask FixBot
    5. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 15, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 15, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: step 15, image 3 of 3
      • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
      Ask FixBot
28 other people completed this guide.
Sam Goldheart
478,462 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
Very clear guide, and highly informative photos. It might be useful to add that the PL5 screws on the back of the case do not insert vertically. These insert at a slight angle and attempting to insert them straight will cause cross treading.
Robert Chave - Reply Share
Simple and clear step by step instructions.
cosilverturq - Reply Share
What is the use of the four foam stickers in step 9? Mine don’t stick anymore after taking out.
Visalbotr Chan - Reply Share
A mi me ha pasado lo mismo. Supongo que sirve para ejercer una pequeña presión sobre los tornillos. Yo le he puesto unas pegatinas, recortadas, de las que se usan para tope de muebles, para que no rocen, y creo que hacen el apaño.
Jose Luis - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 152
All Time: 50,002
