MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement
    1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Heat Sink: step 7, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Heat Sink: step 7, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Heat Sink: step 7, image 3 of 3
      • Carefully remove the rubber fan bumper from the edge of the heat sink.
      • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 9, image 1 of 1
      • Remove the following screws securing the heat sink to the logic board:
      • Four 2.6 mm T5 screws
      • One 2.4 mm Phillips #000 screw
      Ask FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 10, image 2 of 2
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Fan: step 11, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Fan: step 11, image 2 of 2
      • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 12, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 12, image 2 of 2
      • Peel the iSight camera cable off the fan housing to fold it out of the way.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 13, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 13, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 13, image 3 of 3
      • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
      • Carefully pull the fan cable straight out of its socket.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 14, image 1 of 1
      • Remove the following screws securing the fan to the upper case:
      • One 5.0 mm T5 Torx screw
      • Two 3.6 mm T5 Torx screws
      Ask FixBot
    5. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 15, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 15, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 15, image 3 of 3
      • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Logic Board Assembly: step 16, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Logic Board Assembly: step 16, image 2 of 2
      • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
      • Remove the I/O board cable bracket.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 17, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 17, image 2 of 2
      • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
      • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 18, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 18, image 2 of 2
      • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
      • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 19, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 19, image 2 of 2
      • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 20, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 20, image 2 of 2
      • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
      Ask FixBot
    6. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 21, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 21, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 21, image 3 of 3
      • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
      Ask FixBot
    7. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 22, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 22, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 22, image 3 of 3
      • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
      Ask FixBot
    8. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 23, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 23, image 2 of 2
      • Carefully pull the DC-In board connector straight out of its socket on the logic board.
      Ask FixBot
    9. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 24, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 24, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 24, image 3 of 3
      • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
      Ask FixBot
    10. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 25, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 25, image 2 of 2
      • If necessary, peel back any tape covering the microphone cable ZIF connector.
      Ask FixBot
    11. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 26, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 26, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 26, image 3 of 3
      • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
      • Pull the microphone cable out of its socket on the logic board.
      Ask FixBot
    12. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 27, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 27, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 27, image 3 of 3
      • If necessary, peel back any tape covering the keyboard cable connector.
      • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
      Ask FixBot
    13. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 28, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 28, image 2 of 2
      • Pull the keyboard cable straight out of its ZIF socket on the logic board.
      Ask FixBot
    14. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 29, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 29, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 29, image 3 of 3
      • If necessary, peel back any tape covering the trackpad cable connector.
      Ask FixBot
    15. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 30, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 30, image 2 of 2
      • Pull the trackpad ribbon cable straight out of its socket on the logic board.
      Ask FixBot
    16. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 31, image 1 of 1
      • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
      • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
      Ask FixBot
    17. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 32, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 32, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 32, image 3 of 3
      • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
      • Remove the logic board.
      • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
      • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Dual Microphone Assembly: step 33, image 1 of 1
      • Remove the following screws securing the left speaker to the upper case:
      • One 5.7 mm T5 Torx screw
      • One 6.5 mm T5 Torx screw
      • One 3.8 mm T5 Torx screw
      Ask FixBot
    2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 34, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 34, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 34, image 3 of 3
      • Lift the corner of the left speaker up and slide it toward the battery to remove it from the upper case.
      • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 35, image 1 of 1
      • Remove the single 3.7 mm T5 Torx screw securing the case-edge of the battery contact board.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 36, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 36, image 2 of 2
      • Insert the tip of a spudger under the battery-side portion of the rubber microphone cable cover to detach the adhesive there.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 37, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 37, image 2 of 2
      • Use the flat end of a spudger to wedge the battery contact board up slightly to allow room to extract the dual microphone assembly.
      Ask FixBot
    6. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 38, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 38, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 38, image 3 of 3
      Buy
      • Remove the rubber microphone cover with a set of tweezers
      • Be careful not to snag the cover on the screw post in the case or on the battery contact board.
      Ask FixBot
    7. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 39, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 39, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 39, image 3 of 3
      • Insert the tip of a spudger underneath the connector end of the microphone ribbon cable and slide it toward the screw post to free that half from the upper case.
      • If the microphone is very resistant to prying, try heating it with an iOpener. Heating it will soften the adhesive and minimize the risk of tearing the cable.
      Ask FixBot
    8. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 40, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 40, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 40, image 3 of 3
      • Insert the tip of a spudger under the battery-side portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
      Ask FixBot
    9. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 41, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: step 41, image 2 of 2
      • Pull the dual microphone cable assembly up and toward the logic board recess to remove it from the upper case.
      • Be very careful not to snag the cable on the screw post in the case or the battery contact board.
      Ask FixBot
Sam Goldheart
478,462 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
2 Guide Comments
Very clear and concise, thank you.
T Col - Reply Share
Where can you get the replacement microphone? Do you have the part number?
Hanks Caddy - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 112
All Time: 8,598
