MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement
    1. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement, Right Speaker: step 7, image 1 of 1
      • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 8, image 1 of 1
      Buy
      • Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 9, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 9, image 2 of 2
      • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
      • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 10, image 2 of 2
      • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
      • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 11, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 11, image 2 of 2
      • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
      Ask FixBot
    6. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 12, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 12, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 12, image 3 of 3
      • Carefully peel the right speaker cable off the upper case.
      Ask FixBot
    7. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 13, image 1 of 1
      • Remove the following screws securing the right speaker to the upper case:
      • One 5.7 mm T5 Torx screw
      • One 6.5 mm T5 Torx screw
      • One 3.8 mm T5 Torx screw
      Ask FixBot
    8. MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 14, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 14, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Right Speaker Replacement: step 14, image 3 of 3
      • Lift the right speaker from the cable end and pull it free from the case.
      Ask FixBot
72 other people completed this guide.
Sam Goldheart
477,944 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
84,881 Guides authored
8 Guide Comments
Easy to follow guide! completed the installation within half an hour. Thanks guys :)
Jeevan Kumar - Reply Share
Parfait. Comptez 30 min au total. Merci
Jacques Krief - Reply Share
I bought all the suggested tools and parts and changed both the left and the right speaker on my wifes Mac Book Pro in 30 minutes. Fantastic guide and site for fixing things. I will come back to this site in the future for DIY repairs. Thank you.
Jodel Manning - Reply Share
On point, simple and complete, thanks
sintobeanrv - Reply Share
Waaay too easy — thx!
Bruce Coffman - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 132
All Time: 54,070
