MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement
    1. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, MagSafe DC-In Board: step 7, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, MagSafe DC-In Board: step 7, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, MagSafe DC-In Board: step 7, image 3 of 3
      • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
      • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 8, image 2 of 2
      • Pull the DC-In board connector straight out of its socket on the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 9, image 1 of 1
      • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
      • You may need to gently push the display cable out of the way to expose the screws.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 10, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 10, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: step 10, image 3 of 3
      • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
      Ask FixBot
27 other people completed this guide.
Sam Goldheart
478,474 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
7 Guide Comments
How can I know if the magsafe is not working ?
lpelaez - Reply Share
Thanks for great tutorial!
Yep, what are the signs of bad dc-in board?
When I plug in the charger, LED on magsafe connector doesn't light up.
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
For some reason charging doesn't start, my battery has only 600 cycles on it.
Can you guys help?
P.S. I tried plugging other adapters thats working, same thing (
Olga Kolina - Reply Share
Did you ever get a solution? I got a new MacBook Pro and didn’t use this one for 2 months, then went to charge it and nothing happens! No light on the charger and the battery is totally dead! I’m going to replace this DC board and maybe the battery. Did you get yours working?
Billy May - Reply Share
I Have replaced the battery and the machine still works under the power from the new battery but the LED won’t come on the magsafe charger. Now I have replaced the DC In board and still not charging. the charger works on the other Mac in the house. What could the issue be?
Christopher Culler - Reply Share
Will you have the replacement piece available anytime soon ?
hergas - Reply Share
Past 24 Hours: 3
Past 7 Days: 54
Past 30 Days: 199
All Time: 25,580
