MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement
    1. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 3, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 3, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 3, image 3 of 3
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      • The lower case is connected to the upper case at the center, with two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Battery Connector: step 4, image 1 of 1
      • Remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 5, image 1 of 1
      • Remove the following screws securing the battery connector board to the logic board:
      • Two 2.8 mm T6 Torx screws
      • One 7.0 mm T6 Torx shouldered screw
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 6, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 6, image 2 of 2
      Buy
      • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 7, image 1 of 1
      • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 8, image 2 of 2
      • Carefully lift the battery connector board up off the logic board.
      • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
      • Do not fold the board completely over, or crease the cables, as this may damage the battery.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Battery Contact Board: step 9, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Battery Contact Board: step 9, image 2 of 2
      Buy
      • Grasp the Interposer with tweezers.
      • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
      • Lift the Interposer off the logic board and remove it.
      • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Left Speaker: step 10, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Left Speaker: step 10, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Left Speaker: step 10, image 3 of 3
      • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
      • Gently bend the headphone jack cable to 90° up from the logic board.
      • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 11, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 11, image 2 of 2
      • Wedge the tip of a spudger beneath the left speaker cable connector.
      • Gently pry the left speaker cable connector up off from its socket on the logic board.
      • Be sure you are prying up on the connector, not the socket itself.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 12, image 1 of 1
      Buy
      • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
      • One black 6.8 mm screw
      • One silver 6.3 mm screw
      • One black 4.9 mm screw
      • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 13, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: step 13, image 2 of 2
      • Lift and remove the left speaker out of the upper case.
      Ask FixBot
25 other people completed this guide.
5 Guide Comments
Rats:
"Wedge the tip of a spudger beneath the left speaker cable connector.
Be sure you are prying up on the connector, not the socket itself."
I accidentally pried up on the socket, which looks like it was soldered to the board. Left speaker doesn't work, of course. I assume there is no fix for this, other than replacing the board??
Don Sandifer - Reply Share
Thank you very much for the walkthrough. No problems to follow at all. Everything worked as a charm. Changed both speakers as per your other guide.
timofej.se - Reply Share
I was able to follow the steps exactly as described without damaging anything. Patience is the key.
Max Max - Reply Share
This was great! I fixed the computer easily.
Kyle Meyers - Reply Share
Très bon tuto. Clair et précis. Changement des 2 HP en moins d'1 heure.
Bravo à l'équipe.
Dominique BONNEL - Reply Share
Past 24 Hours: 7
Past 7 Days: 31
Past 30 Days: 135
All Time: 19,603
