MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 3, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 3, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 3, image 3 of 3
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      • The lower case is connected to the upper case at the center, with two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Battery Connector: step 4, image 1 of 1
      • Remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 5, image 1 of 1
      • Remove the following screws securing the battery connector board to the logic board:
      • Two 2.8 mm T6 Torx screws
      • One 7.0 mm T6 Torx shouldered screw
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 6, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 6, image 2 of 2
      Buy
      • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 7, image 1 of 1
      • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 8, image 2 of 2
      • Carefully lift the battery connector board up off the logic board.
      • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
      • Do not fold the board completely over, or crease the cables, as this may damage the battery.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Battery Contact Board: step 9, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Battery Contact Board: step 9, image 2 of 2
      Buy
      • Grasp the Interposer with tweezers.
      • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
      • Lift the Interposer off the logic board and remove it.
      • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, iSight Camera Cable: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, iSight Camera Cable: step 10, image 2 of 2
      • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
      • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 11, image 1 of 1
      • Move the iSight camera cable aside.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, AirPort Board Assembly: step 12, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, AirPort Board Assembly: step 12, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, AirPort Board Assembly: step 12, image 3 of 3
      • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
      • The three cables are coded with black sleeves of different lengths. During reassembly:
      • Connect the long-sleeved cable to the socket closest to the ports.
      • The short-sleeved cable connects next to the screw.
      • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 13, image 1 of 1
      • Move the antenna cables aside, clear of the AirPort board.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Display Assembly: step 14, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Display Assembly: step 14, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Display Assembly: step 14, image 3 of 3
      • Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 15, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 15, image 2 of 2
      Buy
      • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 16, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 16, image 2 of 2
      • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge brackets.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 17, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 17, image 2 of 2
      • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 18, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 18, image 2 of 2
      • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
      Ask FixBot
    6. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 19, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 19, image 2 of 2
      • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
      • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • Remove the last remaining T8 Torx screw securing the display to the upper case.
      Ask FixBot
    7. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 20, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 20, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 20, image 3 of 3
      • Grip both halves of the device, one in each hand.
      • Gently push forward on the bottom half of the device to detach it from the display assembly.
      • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, LCD Cable: step 21, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, LCD Cable: step 21, image 2 of 2
      • With the display facing towards you and the plastic clutch cover down, grab the clutch cover and slide it all the way to the right, towards the hinge.
      • Lift the plastic cover from the bottom and remove it from the display.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 22, image 1 of 1
      • Peel up the tape covering the cable connector.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 23, image 1 of 1
      • Remove the two screws securing the cable to the case:
      • Two T8 Torx screws.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 24, image 1 of 1
      • Remove the six screws securing the antenna assembly in place:
      • Six PH00 Phillips screws.
      • Lift the antenna assembly to reveal the LCD cable connector underneath the left side.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: step 25, image 1 of 1
      • Grab the metal bar securing the LCD cable connector in place and rotate it towards the bottom of the display.
      • Pull the LCD cable straight out of its socket on the display.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the display.
      Ask FixBot
4 other people completed this guide.
Jonah Aragon
5,746 Reputation
5 Guides authored
Experimax Coon Rapids Member of Experimax Coon Rapids
Business
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 120
All Time: 7,706
