MacBook Pro 13" Retina Display Late 2012 Battery Replacement
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 3, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 3, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 3, image 3 of 3
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      • The lower case is connected to the upper case at the center, with two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Battery Connector: step 4, image 1 of 1
      • Remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 5, image 1 of 1
      • Remove the following screws securing the battery connector board to the logic board:
      • Two 2.8 mm T6 Torx screws
      • One 7.0 mm T6 Torx shouldered screw
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 6, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 6, image 2 of 2
      Buy
      • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 7, image 1 of 1
      • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 8, image 2 of 2
      • Carefully lift the battery connector board up off the logic board.
      • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
      • Do not fold the board completely over, or crease the cables, as this may damage the battery.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Battery Contact Board: step 9, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Battery Contact Board: step 9, image 2 of 2
      Buy
      • Grasp the Interposer with tweezers.
      • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
      • Lift the Interposer off the logic board and remove it.
      • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, I/O Board Data Cable: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, I/O Board Data Cable: step 10, image 2 of 2
      • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
      • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 11, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 11, image 2 of 2
      • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
      • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 12, image 1 of 1
      • Lift and remove the I/O board data cable from the MacBook Pro.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Right Speaker: step 13, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Right Speaker: step 13, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Right Speaker: step 13, image 3 of 3
      • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
      • Move the SSD cable connector out of the way.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 14, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 14, image 2 of 2
      • Wedge the pointed end of a spudger beneath the right speaker cable connector.
      • Gently pry the right speaker cable connector up off from its socket on the logic board.
      • Be sure you are prying up on the connector, not the socket itself.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 15, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 15, image 2 of 2
      Buy
      • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
      • One black 6.8 mm screw
      • One silver 6.3 mm screw
      • One black 4.9 mm screw
      • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 16, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 16, image 2 of 2
      • Lift and remove the right speaker out of the upper case.
      • If necessary, de-route the right speaker cable from its channel in the upper case.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Left Speaker: step 17, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Left Speaker: step 17, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Left Speaker: step 17, image 3 of 3
      • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
      • Gently bend the headphone jack cable to 90° up from the logic board.
      • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 18, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 18, image 2 of 2
      • Wedge the tip of a spudger beneath the left speaker cable connector.
      • Gently pry the left speaker cable connector up off from its socket on the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 19, image 1 of 1
      Buy
      • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 20, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 20, image 2 of 2
      • Lift and remove the left speaker out of the upper case.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, SSD Assembly: step 21, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, SSD Assembly: step 21, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, SSD Assembly: step 21, image 3 of 3
      • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
      • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 22, image 1 of 1
      • Remove the SSD assembly from the upper case.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Battery: step 23, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement, Battery: step 23, image 2 of 2
      • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 24, image 1 of 1
      • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
      • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 25, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 25, image 2 of 2
      • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 26, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 26, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 26, image 3 of 3
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 27, image 1 of 1
      • Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
      • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
      • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
      Ask FixBot
    6. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 28, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 28, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 28, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
      • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
      Ask FixBot
    7. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 29, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 29, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 29, image 3 of 3
      • Insert the spudger along the left-hand side of the leftmost battery cell.
      • Run the spudger up along the left side of the leftmost battery cell.
      • Slightly pry the leftmost battery cell to release it from the adhesive.
      Ask FixBot
    8. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 30, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 30, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 30, image 3 of 3
      • Repeat the above steps to separate the adjacent battery cell from its adhesive:
      • Apply a few drops of liquid adhesive remover under the battery cell.
      • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
      • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
      Ask FixBot
    9. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 31, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 31, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 31, image 3 of 3
      • Insert the flat end of a spudger underneath the larger leftmost battery cell.
      • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
      • Pry the larger leftmost battery cell up off the upper case.
      Ask FixBot
    10. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 32, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 32, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 32, image 3 of 3
      • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
      • Leave the battery cells resting on top of the upper case as shown in the third picture.
      Ask FixBot
    11. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 33, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 33, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 33, image 3 of 3
      • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
      • Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
      • Be careful not to puncture or otherwise damage the battery cells.
      Ask FixBot
    12. MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 34, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 34, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement: step 34, image 3 of 3
      • Lift the battery as a whole up out of the upper case, and remove the battery.
      • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
      • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
      • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
      • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
      • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
      • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
      Ask FixBot
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 13” Answers community for help.
251 other people completed this guide.
63 Guide Comments
There is a much easier way to get the batteries out. If you look at the 2 cells on either side (left and right), you will notice that they put them in an area that is slightly lowered. This is by design. To remove the batteries, pour a small amount of 90% isopropyl alcohol on both sides and let it sit for about 30 to 45 mins. It will dissolve the glue and you can gently then lift out the batteries without any prying. After you remove the batteries, simply wipe up any remaining alcohol, let it dry, buff it clean, and insert the new battery. Considerably easier and safer than potentially damaging the battery packs. If you are putting the same battery pack back, just use double sided tape. IMPORTANT NOTE: ALWAYS BE SAFE USING ISOPROPYL ALCOHOL AROUND FLAMES OR ANYTHING THAT MIGHT MAKE IT BURN. ALSO, NEVER ATTEMPT TO PRY THE BATTERIES IN ANY WAY IF ANY ALCOHOL IS STILL POTENTIALLY PRESENT!! WAIT UNTIL IT IS EVAPORATED!!
jimhoffa69 - Reply Share
Thank You for the hint with the alcohol, but where can I buy a spare battery?
Uli - Reply Share
I poured isopropanol into those lowered areas but unfortunately it soaked up along the battery leads and got all the way under the keyboard and elsewhere where it shouldn’t. It made some other plastic parts of the computer swell which isn’t good so I would not recommend pouring any solvent in there. Add a very small amount of solvent (0.25 ml) just enough to soften the adhesive, and let it sit for about 30 min and then pry carefully and add a little more, making sure it doesn’t get soaked up by the battery leads.
Another important thing: when you buy a battery, make sure it’s new, up to 1 year from date of manufacture because they have a limited shelf life and get permanently damaged when sitting uncharged.
Imre Treufeld - Reply Share
Prying the battery out is HARD! and VERY dangerous. I tried using a flat head screwdriver, put it under the battery and twisting the thing out. DO NOT DO THAT!! as it can punch a hole in the battery if you twist it too hard. I had a small smoke coming off by doing that and was lucky enough it didn't burn. Using isopropyl would be an ideal solution. But to bad I can't find that around here :(.
[DO THIS ON YOUR OWN RISK] What I ended up doing is using the screwdriver to gouge the underlying glue out as much as I can on the side (about 10%) and use fingers to pry it up. Good luck!
Hlung - Reply Share
Perfect! not as difficult as it looked first, especially with the proper tools. To take the batteries out the alcohol (I used ethanol used for cleaning purposes) works like charm. I put a few ml in nearby the batteries, waited maybe 20min and was able to pry them out easily. Tried before without the alocohol and nothing moved. I ordered the battery on ebay for 70€ and it has the same numbers and text as the original it says apple japan as well. My old battery had more than a thousand cycles after 3 years and did not last vey long. Now the software shows 0 cycles and it is charging starting at 15% and will be fully charged in 2:45h. I think apple charges 249€ for the job here in Gernany. It took me about 1 hour to replace it (with waiting).
Olaf Querhammer - Reply Share
Past 24 Hours: 18
Past 7 Days: 94
Past 30 Days: 466
All Time: 196,368
