MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement
    1. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Right Speaker: step 7, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Right Speaker: step 7, image 2 of 2
      • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
      • Remove the I/O board cable bracket.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
      • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 9, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 9, image 2 of 2
      • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
      • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 10, image 2 of 2
      • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 11, image 1 of 3 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 11, image 2 of 3 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 11, image 3 of 3
      • Carefully peel the right speaker cable off the upper case.
      Ask FixBot
    6. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 12, image 1 of 1
      • Remove the following screws securing the right speaker to the upper case:
      • One 5.7 mm T5 Torx screw
      • One 6.5 mm T5 Torx screw
      • One 3.8 mm T5 Torx screw
      Ask FixBot
    7. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 13, image 1 of 3 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 13, image 2 of 3 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: step 13, image 3 of 3
      • Lift the right speaker from the cable end and pull it free from the case.
      Ask FixBot
86 other people completed this guide.
Andrew Optimus Goldheart
515,529 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
123 Members
81,769 Guides authored
5 Guide Comments
my Speaker tone … can i stitch it ?
Mr Jay - Reply Share
Il ne faut surement pas plier la nappe de la carte E/S mais dévisser son support afin de ne pas l’endommager. Une fois pliée, elle ne reviendra jamais parfaitement droite. Il y a deux petites vis qui maintiennent le support qu’il faut dévisser, à moins qu’il y ait encore quelque chose de caché !
Yves Cirotteau - Reply Share
why do I need to disconnect the battery in order to replace the speaker?
Ohad S - Reply Share
It is best to always disconnect power from any device you’re working on. Worst case scenario you lay a screw driver down on the device or drop a conductive piece of metal somewhere into the case and it shorts out the board you’re working on. This is the safest way to do repairs.
Elliott Fix - Reply Share
Will this be back in stock in the UK anytime soon?
Itamar Mor - Reply Share
Past 24 Hours: 14
Past 7 Days: 111
Past 30 Days: 527
All Time: 92,218
