Up to 20% off select tools
MacBook Neo Trackpad Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
14
Past 7 Days:
66
Past 30 Days:
332
All Time:
1,443
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a broken or cracked trackpad in a MacBook Neo.
For your safety, discharge the battery below 25% before disassembly. This reduces the risk of a dangerous fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions and replace it using this guide.
    1. MacBook Neo Trackpad Replacement, Prepare the MacBook for disassembly: step 1, image 1 of 3 MacBook Neo Trackpad Replacement, Prepare the MacBook for disassembly: step 1, image 2 of 3 MacBook Neo Trackpad Replacement, Prepare the MacBook for disassembly: step 1, image 3 of 3
      • Fully shut down the MacBook and close the lid. Keep the lid closed until you've physically disconnected the battery.
      • Disconnect any cables and accessories.
      • Flip the computer upside‑down on a clean work surface.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Remove the bottom cover screws: step 2, image 1 of 1
      • Use a P5 pentalobe driver to remove the eight screws securing the bottom cover:
      • Six 4.1 mm‑long screws
      • Two 4.5 mm‑long screws
      Ask FixBot
    2. MacBook Neo Trackpad Replacement, Pry up the bottom cover: step 3, image 1 of 3 MacBook Neo Trackpad Replacement, Pry up the bottom cover: step 3, image 2 of 3 MacBook Neo Trackpad Replacement, Pry up the bottom cover: step 3, image 3 of 3
      • The bottom cover is held in place with two clips, one on each side.
      • Use your fingers to pry up the bottom cover from the top‑right corner, near the USB‑C ports, until the clip along the right edge of the laptop pops up.
      • If you're having trouble, use the flat end of a spudger to pry up the corner until you can grab it with your fingers. You can also slide an opening pick down each edge to release the clips.
      • Repeat this process on the left side to release its clip.
      Ask FixBot
    3. MacBook Neo Trackpad Replacement, Remove the bottom cover: step 4, image 1 of 2 MacBook Neo Trackpad Replacement, Remove the bottom cover: step 4, image 2 of 2
      • Pick up the bottom cover and lift it off the MacBook.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Remove the battery connector cover: step 5, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the battery connector cover.
      • While the MacBook Neo uses Torx Plus screws, standard Torx bits also work (T3 in place of 3IP, for example). Apply constant, downward force to prevent stripping.
      Ask FixBot
    2. MacBook Neo Trackpad Replacement: step 6, image 1 of 2 MacBook Neo Trackpad Replacement: step 6, image 2 of 2
      • Use tweezers or your fingers to remove the battery connector cover.
      Ask FixBot
    3. MacBook Neo Trackpad Replacement, Disconnect the battery: step 7, image 1 of 2 MacBook Neo Trackpad Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Disconnect the trackpad: step 8, image 1 of 2 MacBook Neo Trackpad Replacement, Disconnect the trackpad: step 8, image 2 of 2
      • Use the flat end of a spudger to lift the hinged locking flap on the trackpad cable ZIF connector.
      Ask FixBot
    2. MacBook Neo Trackpad Replacement: step 9, image 1 of 2 MacBook Neo Trackpad Replacement: step 9, image 2 of 2
      • Use tweezers or your fingers to gently pull the trackpad cable out of its socket.
      Ask FixBot
    3. MacBook Neo Trackpad Replacement, Remove the trackpad base plate screws: step 10, image 1 of 1
      • Use a Torx Plus 8IP driver to remove the four 5.3 mm‑long black screws securing the trackpad base plate.
      Ask FixBot
    4. MacBook Neo Trackpad Replacement, Remove the trackpad base plate: step 11, image 1 of 3 MacBook Neo Trackpad Replacement, Remove the trackpad base plate: step 11, image 2 of 3 MacBook Neo Trackpad Replacement, Remove the trackpad base plate: step 11, image 3 of 3
      • Pick up and remove the trackpad base plate.
      Ask FixBot
    5. MacBook Neo Trackpad Replacement, Remove the trackpad screws: step 12, image 1 of 1
      • Use a Torx Plus 8IP driver to remove the four 5.0 mm‑long silver screws securing the trackpad.
      Ask FixBot
    6. MacBook Neo Trackpad Replacement, Remove the trackpad: step 13, image 1 of 3 MacBook Neo Trackpad Replacement, Remove the trackpad: step 13, image 2 of 3 MacBook Neo Trackpad Replacement, Remove the trackpad: step 13, image 3 of 3
      • Pick up the trackpad from the center and slide it out from beneath its cable to remove it.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Disassembly complete: step 14, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble the MacBook.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Install the trackpad: step 15, image 1 of 3 MacBook Neo Trackpad Replacement, Install the trackpad: step 15, image 2 of 3 MacBook Neo Trackpad Replacement, Install the trackpad: step 15, image 3 of 3
      • Hold the new trackpad from the center to slide it beneath its cable and set it into the frame.
      Ask FixBot
    2. MacBook Neo Trackpad Replacement, Install the trackpad screws: step 16, image 1 of 1
      • Use a Torx Plus 8IP driver to install the four 5.0 mm‑long silver screws securing the trackpad.
      Ask FixBot
    3. MacBook Neo Trackpad Replacement, Install the trackpad base plate: step 17, image 1 of 2 MacBook Neo Trackpad Replacement, Install the trackpad base plate: step 17, image 2 of 2
      • Align the trackpad base plate with its screw holes, making sure the notch on its long edge is facing the battery.
      • Set the trackpad base plate into place.
      Ask FixBot
    4. MacBook Neo Trackpad Replacement, Install the trackpad base plate screws: step 18, image 1 of 1
      • Use a Torx Plus 8IP driver to install the four 5.3 mm‑long black screws securing the trackpad base plate.
      Ask FixBot
    5. MacBook Neo Trackpad Replacement, Connect the trackpad: step 19, image 1 of 3 MacBook Neo Trackpad Replacement, Connect the trackpad: step 19, image 2 of 3 MacBook Neo Trackpad Replacement, Connect the trackpad: step 19, image 3 of 3
      • Make sure the locking flap is flipped up and gently insert the trackpad cable into its socket.
      • Flip the locking flap down to secure the cable.
      Ask FixBot
    6. MacBook Neo Trackpad Replacement, Loosen the trackpad screws: step 20, image 1 of 2 MacBook Neo Trackpad Replacement, Loosen the trackpad screws: step 20, image 2 of 2
      • Use a Torx Plus 8IP driver to loosen (not remove) the four 5.0 mm‑long silver screws securing the trackpad.
      Ask FixBot
    7. MacBook Neo Trackpad Replacement, Align the trackpad: step 21, image 1 of 3 MacBook Neo Trackpad Replacement, Align the trackpad: step 21, image 2 of 3 MacBook Neo Trackpad Replacement, Align the trackpad: step 21, image 3 of 3
      • Cut a stack of two sticky notes horizontally in half, then vertically into four equally‑sized pieces.
      • Slide the non-sticky side of each piece into the gap between the trackpad and the frame, centrally on each edge.
      • Fold each piece down and adhere it to the laptop.
      Ask FixBot
    8. MacBook Neo Trackpad Replacement, Tighten the trackpad screws: step 22, image 1 of 3 MacBook Neo Trackpad Replacement, Tighten the trackpad screws: step 22, image 2 of 3 MacBook Neo Trackpad Replacement, Tighten the trackpad screws: step 22, image 3 of 3
      • Close the laptop, flip it upside down, and use a Torx Plus 8IP driver to tighten the four 5.0 mm‑long silver screws securing the trackpad.
      • Reopen the laptop, remove the sticky notes, and inspect it to ensure it's centered. If it isn't, loosen the screws from the last bullet and hold it in the correct position while you tighten them.
      • Carefully close the laptop.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Connect the battery: step 23, image 1 of 2 MacBook Neo Trackpad Replacement, Connect the battery: step 23, image 2 of 2
      • Align the battery connector carefully over its socket and press down until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. MacBook Neo Trackpad Replacement, Install the battery connector cover: step 24, image 1 of 3 MacBook Neo Trackpad Replacement, Install the battery connector cover: step 24, image 2 of 3 MacBook Neo Trackpad Replacement, Install the battery connector cover: step 24, image 3 of 3
      • Set the battery connector cover in place, aligned with its screw holes.
      • Use a Torx Plus 3IP driver to install the two 1.7 mm‑long screws securing the battery connector cover.
      Ask FixBot
    1. MacBook Neo Trackpad Replacement, Install the bottom cover: step 25, image 1 of 2 MacBook Neo Trackpad Replacement, Install the bottom cover: step 25, image 2 of 2
      • Align the bottom cover with its screw holes, then press on the two short sides until the clip on each side snaps into place.
      Ask FixBot
    2. MacBook Neo Trackpad Replacement, Install the bottom cover screws: step 26, image 1 of 1
      • To ensure alignment, we recommend you partially install all the screws before fully tightening them.
      • Use a P5 pentalobe driver to install the eight screws securing the bottom cover:
      Ask FixBot
Congratulations on completing your repair!
Author
with
Nick Schultz
71,397 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 66
Past 30 Days: 332
All Time: 1,443
