This teardown is not a repair guide. To repair your MacBook Neo, use our service manual.
    1. MacBook Neo Chip ID, Main Board - Front Side: step 1, image 1 of 2 MacBook Neo Chip ID, Main Board - Front Side: step 1, image 2 of 2
      • Apple APL1V07 / 339S01851 A18 Pro applications processor layered under a SK hynix H58G66CK8HX139 8 GB LPDDR5X SDRAM memory
      • Apple APL109A / 343S00866 power management
      • SanDisk SDMVGKLK8-512G 512 GB NAND flash memory
      • Likely Apple 338S01330-B0 battery charger
      • NXP Semiconductors SE310S secure element
      • Texas Instruments SN2012027 USB Type-C port controller
      • Winbond W25Q80DV 1 MB serial NOR flash memory
      Ask FixBot
    2. MacBook Neo Chip ID: step 2, image 1 of 1
      • VIA Labs VL122-Q2 4-port USB 2.0 hub
      • Apple APL109O / 343S00861 power management
      • Cirrus Logic CS42L83A audio codec
      • Analog Devices MAX98360B 3.2 W audio amplifier
      • Texas Instruments TPS630250 adjustable buck-boost converter
      • Texas Instruments TPS61022 8 A boost converter
      • Possibly Texas Instruments LM3638 LED backlight driver
      Ask FixBot
    3. MacBook Neo Chip ID: step 3, image 1 of 1
      • Likely GigaDevice serial NOR flash memory
      • Likely STMicroelectronics serial EEPROM memory
      • Likely Texas Instruments eUSB2-USB 2.0 dual repeater
      • DC-DC converter
      • Texas Instruments INA190A3 current sense amplifier
      • current sense amplifier
      • Texas Instruments TPS259482A 8 A eFuse
      Ask FixBot
    4. MacBook Neo Chip ID: step 4, image 1 of 1
      • Texas Instruments TLV4041R1 single comparator w/ reference
      • Likely Renesas SLG46108 programmable mixed signal matrix
      • Likely Renesas mixed signal array
      • Likely Renesas SLG4xxxx mixed signal array
      • Texas Instruments TPS7A2018P 300 mA / 1.8 V LDO regulator
      • Nexperia 74AVC4T245GU 4-bit dual-supply translating transceiver
      • Texas Instruments SN74AVC4T774 4-bit dual-supply bus transceiver
      Ask FixBot
    5. MacBook Neo Chip ID: step 5, image 1 of 1
      • Texas Instruments LSF0101 single bidirectional multi-voltage level translator
      • Nexperia 74AXP1T45GX 1-bit dual-supply translating transceiver
      • Texas Instruments SN74AUP1G17 single Schmitt-trigger buffer
      • Texas Instruments SN74AUP1G08 single AND gate
      • Nexperia 74AUP1G08GM single AND gate
      • Texas Instruments SN74AUP1G34 single buffer
      Ask FixBot
    6. MacBook Neo Chip ID: step 6, image 1 of 1
      • MediaTek MT7932EEA Wi-Fi 6E & Bluetooth 6 controller
      • Likely Sony CXA4626GC RF switch
      Ask FixBot
    7. MacBook Neo Chip ID, Main Board - Back Side: step 7, image 1 of 2 MacBook Neo Chip ID, Main Board - Back Side: step 7, image 2 of 2
      Ask FixBot
    8. MacBook Neo Chip ID, Touchpad: step 8, image 1 of 1
      • Broadcom BCM5976TC1KFB3G touchpad controller
      Ask FixBot
0 Guide Comments
Past 24 Hours: 22
Past 7 Days: 128
Past 30 Days: 605
All Time: 3,671
