Parts
Tools
Introduction
Go to step 1 ↓Follow this guide to replace a damaged bottom cover on a MacBook Neo.
For your safety, discharge the battery below 25% before disassembly. This reduces the risk of a dangerous fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Fully shut down the MacBook and close the lid. Keep the lid closed until you've physically disconnected the battery.
Disconnect any cables and accessories.
Flip the computer upside‑down on a clean work surface.
Use a P5 pentalobe driver to remove the eight screws securing the bottom cover:
Six 4.1 mm‑long screws
Two 4.5 mm‑long screws
Use your fingers to lift the top right corner of the bottom cover, near the USB‑C ports, until the clip along the right edge releases.
Repeat this process on the left side to release its clip.
Compare the new replacement part to the original part—you may need to remove plastic liners from the new part before you install it.
To reassemble the MacBook, follow these instructions in reverse order.
2 other people completed this guide.
