Up to 20% off select tools
MacBook Core Duo PRAM Battery Replacement
Views: 99K
View statistics:
Past 24 Hours:
9
Past 7 Days:
38
Past 30 Days:
207
All Time:
98,949
Comments: 109
105 comments on steps, 4 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Parts
Tools
  • Coin
    $2.99
    4.7
    View
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off. If you feel like you're stuck in the movie Groundhog Day, replace the PRAM battery and finally turn the page of your calendar.
    1. MacBook Core Duo PRAM Battery Replacement, Battery: step 1, image 1 of 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      Ask FixBot
    2. MacBook Core Duo PRAM Battery Replacement: step 2, image 1 of 1
      • Lift the battery out of the computer.
      Ask FixBot
    1. MacBook Core Duo PRAM Battery Replacement, Memory Cover: step 3, image 1 of 1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      Ask FixBot
    2. MacBook Core Duo PRAM Battery Replacement: step 4, image 1 of 1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      Ask FixBot
    1. MacBook Core Duo PRAM Battery Replacement, Upper Case: step 5, image 1 of 1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      Ask FixBot
    2. MacBook Core Duo PRAM Battery Replacement: step 6, image 1 of 1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      Ask FixBot
    3. MacBook Core Duo PRAM Battery Replacement: step 7, image 1 of 1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      Ask FixBot
    4. MacBook Core Duo PRAM Battery Replacement: step 8, image 1 of 1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      Ask FixBot
    5. MacBook Core Duo PRAM Battery Replacement: step 9, image 1 of 1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      Ask FixBot
    6. MacBook Core Duo PRAM Battery Replacement: step 10, image 1 of 1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      Ask FixBot
    7. MacBook Core Duo PRAM Battery Replacement: step 11, image 1 of 1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      Ask FixBot
    8. MacBook Core Duo PRAM Battery Replacement: step 12, image 1 of 1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      Ask FixBot
    1. MacBook Core Duo PRAM Battery Replacement, Left I/O Frame: step 13, image 1 of 1
      • Disconnect the MagSafe board cable from the logic board.
      Ask FixBot
    2. MacBook Core Duo PRAM Battery Replacement: step 14, image 1 of 1
      • Remove the single Phillips screw securing the left speaker to the lower case.
      • Lift the left speaker out of its housing and set it to the side.
      Ask FixBot
    3. MacBook Core Duo PRAM Battery Replacement: step 15, image 1 of 1
      • Two 7.5 mm Phillips from either end of the left I/O frame.
      • One 9 mm Phillips from the middle of the left I/O frame.
      • Remove the small black plastic spacer at the bottom of the left I/O frame.
      Ask FixBot
    4. MacBook Core Duo PRAM Battery Replacement: step 16, image 1 of 1
      • Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
      Ask FixBot
    1. MacBook Core Duo PRAM Battery Replacement, Logic Board: step 17, image 1 of 1
      • Peel up the foil tape between the fan and the optical drive.
      Ask FixBot
    2. MacBook Core Duo PRAM Battery Replacement: step 18, image 1 of 1
      • Use a spudger to move the gray display data and black speaker cables to the right. This will reveal a silver screw securing the fan housing to the lower case.
      Ask FixBot
    3. MacBook Core Duo PRAM Battery Replacement: step 19, image 1 of 1
      • Disconnect the orange optical drive ribbon cable from the logic board.
      Ask FixBot
    4. MacBook Core Duo PRAM Battery Replacement: step 20, image 1 of 1
      • Peel up the small black rubber cover from the right side of the heat sink.
      Ask FixBot
    5. MacBook Core Duo PRAM Battery Replacement: step 21, image 1 of 1
      • Disconnect the black fan connector and two white temperature sensor connectors from the logic board.
      Ask FixBot
    6. MacBook Core Duo PRAM Battery Replacement: step 22, image 1 of 1
      • Remove the following 6 screws:
      • One 3 mm Phillips on the right side of the fan.
      • One 6 mm Phillips on the left side of the fan.
      • Four 9 mm Phillips securing the heat sink to the lower case.
      Ask FixBot
    7. MacBook Core Duo PRAM Battery Replacement: step 23, image 1 of 1
      • Hold the heat sink with one hand and the fan with your other hand, and lift the heat sink and fan assembly out of the computer. The fan is attached to the heat sink only with a strip of black felt tape, so be sure to remove both parts as a unit
      • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
      Ask FixBot
    8. MacBook Core Duo PRAM Battery Replacement: step 24, image 1 of 1
      • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board.
      Ask FixBot
    9. MacBook Core Duo PRAM Battery Replacement: step 25, image 1 of 1
      • Remove the following 2 screws from the Airport card:
      • One 3 mm Phillips from the left side.
      • One 8 mm Phillips from the right side.
      Ask FixBot
    10. MacBook Core Duo PRAM Battery Replacement: step 26, image 1 of 1
      • Grasp the Airport card at its top and slide it toward the screen and out of the computer.
      Ask FixBot
    11. MacBook Core Duo PRAM Battery Replacement: step 27, image 1 of 1
      • Use a spudger to disconnect the left speaker connector from the logic board.
      • Lift the left speaker out of the computer.
      Ask FixBot
    12. MacBook Core Duo PRAM Battery Replacement: step 28, image 1 of 1
      • Disconnect the display data cable by pulling up on the black plastic pull-tab. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
      Ask FixBot
    13. MacBook Core Duo PRAM Battery Replacement: step 29, image 1 of 1
      • Disconnect the newly-revealed hard drive cable from the logic board.
      Ask FixBot
    14. MacBook Core Duo PRAM Battery Replacement: step 30, image 1 of 1
      • Use a spudger to disconnect the two speaker connectors from the logic board.
      Ask FixBot
    15. MacBook Core Duo PRAM Battery Replacement: step 31, image 1 of 1
      • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
      Ask FixBot
    16. MacBook Core Duo PRAM Battery Replacement: step 32, image 1 of 1
      • Deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
      Ask FixBot
    17. MacBook Core Duo PRAM Battery Replacement: step 33, image 1 of 1
      • Use a spudger to carefully pry the battery connector up and disconnect it from the logic board.
      Ask FixBot
    18. MacBook Core Duo PRAM Battery Replacement: step 34, image 1 of 1
      • Remove the three 3 mm Phillips screws securing the logic board to the lower case.
      Ask FixBot
    19. MacBook Core Duo PRAM Battery Replacement: step 35, image 1 of 1
      • Lift the logic board up from the right side, and slide it up and out of the computer.
      Ask FixBot
    1. MacBook Core Duo PRAM Battery Replacement, PRAM Battery: step 36, image 1 of 1
      • Turn the logic board over.
      • Peel the PRAM battery up from its location on the logic board, removing tape as necessary.
      Ask FixBot
    2. MacBook Core Duo PRAM Battery Replacement: step 37, image 1 of 1
      • Disconnect the PRAM battery cable from the logic board and remove the PRAM battery from the computer.
      Ask FixBot
20 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
4 Guide Comments
Unfortunately not all A1181s use the replaceable battery - some use a Super-Cap. Certainly mine did, after spending 1/2 hour opening it up and flipper the case over I find no replaceable battery, rather a small device labeled “V C2800” almost under J4501 (HDD). Mine charges up to 2.8V with the AC power adapter hooked up, but quickly discharges to 0.9VDC once power is removed. I shall see if the SuperCap at Digi-Key works better…https://www.digikey.ca/product-detail/en...
Here is discussion on the SuperCap version: Is there no CMOS RAM battery on this model?
John Robertson - Reply Share
mine not use the replaceable battery either
Hariza Akbar - Reply Share
My Black A1181 had a BR1632 battery, and a straighter heat sink pipe.. but the battery was just underneath the DVD drive so no need to go through all this wor to remove the board and heat sink. Just unscrew the DVD drive, tape, and 5 cable connectors…
RayRay - Reply Share
Also … actually if U don’t have a BR1632 a CR2016 fits snugly ( bit larger diameter) but only 100mAh vs the C2025 which has 160-170mAh and CR2032 which has 210mAh. I went with the CR2025 , cables still routed around it enough to fit the DVD drive back in over the top.
Past 24 Hours: 9
Past 7 Days: 38
Past 30 Days: 207
All Time: 98,949
