Up to 20% off select tools
MacBook Core Duo Left I/O Frame Replacement
Views: 15K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
104
All Time:
15,378
Comments: 90
90 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • Coin
    $2.99
    4.7
    View
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace the frame over the ports on the left side of your MacBook Core Duo.
    1. MacBook Core Duo Left I/O Frame Replacement, Battery: step 1, image 1 of 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      Ask FixBot
    2. MacBook Core Duo Left I/O Frame Replacement: step 2, image 1 of 1
      • Lift the battery out of the computer.
      Ask FixBot
    1. MacBook Core Duo Left I/O Frame Replacement, Memory Cover: step 3, image 1 of 1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      Ask FixBot
    2. MacBook Core Duo Left I/O Frame Replacement: step 4, image 1 of 1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      Ask FixBot
    1. MacBook Core Duo Left I/O Frame Replacement, Upper Case: step 5, image 1 of 1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      Ask FixBot
    2. MacBook Core Duo Left I/O Frame Replacement: step 6, image 1 of 1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      Ask FixBot
    3. MacBook Core Duo Left I/O Frame Replacement: step 7, image 1 of 1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      Ask FixBot
    4. MacBook Core Duo Left I/O Frame Replacement: step 8, image 1 of 1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      Ask FixBot
    5. MacBook Core Duo Left I/O Frame Replacement: step 9, image 1 of 1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      Ask FixBot
    6. MacBook Core Duo Left I/O Frame Replacement: step 10, image 1 of 1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      Ask FixBot
    7. MacBook Core Duo Left I/O Frame Replacement: step 11, image 1 of 1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      Ask FixBot
    8. MacBook Core Duo Left I/O Frame Replacement: step 12, image 1 of 1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      Ask FixBot
    1. MacBook Core Duo Left I/O Frame Replacement, Left I/O Frame: step 13, image 1 of 1
      • Disconnect the MagSafe board cable from the logic board.
      Ask FixBot
    2. MacBook Core Duo Left I/O Frame Replacement: step 14, image 1 of 1
      • Remove the single Phillips screw securing the left speaker to the lower case.
      • Lift the left speaker out of its housing and set it to the side.
      Ask FixBot
    3. MacBook Core Duo Left I/O Frame Replacement: step 15, image 1 of 1
      • Two 7.5 mm Phillips from either end of the left I/O frame.
      • One 9 mm Phillips from the middle of the left I/O frame.
      • Remove the small black plastic spacer at the bottom of the left I/O frame.
      Ask FixBot
    4. MacBook Core Duo Left I/O Frame Replacement: step 16, image 1 of 1
      • Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
      Ask FixBot
3 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 104
All Time: 15,378
