Up to 20% off select tools
MacBook Core Duo Hard Drive Replacement
Views: 439K
View statistics:
Past 24 Hours:
9
Past 7 Days:
53
Past 30 Days:
279
All Time:
438,620
Comments: 60
40 comments on steps, 20 guide comments.
Go to guide comments
Completed: 614
614 people have marked this guide "completed." Will you be next?
Favorites: 72
72 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 30 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Replace or upgrade your MacBook Core Duo's hard drive with a new SATA hard drive or SSD up to 9.5mm thick. A new drive can give you extra storage space and also increase your MacBook's speed.
Video Overview
    1. MacBook Core Duo Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      Ask FixBot
    2. MacBook Core Duo Hard Drive Replacement: step 2, image 1 of 1
      • Lift the battery out of the computer.
      Ask FixBot
    1. MacBook Core Duo Hard Drive Replacement, Memory Cover: step 3, image 1 of 1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      Ask FixBot
    2. MacBook Core Duo Hard Drive Replacement: step 4, image 1 of 1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      Ask FixBot
    1. MacBook Core Duo Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
      • The hard drive goes back into its compartment with the label facing down.
      Ask FixBot
    1. MacBook Core Duo Hard Drive Replacement, Hard Drive: step 6, image 1 of 1
      • Remove the two black T8 Torx screws securing the silver bracket to the hard drive.
      Ask FixBot
    2. MacBook Core Duo Hard Drive Replacement: step 7, image 1 of 1
      • Rotate the hard drive and remove the two black T8 Torx screws on the other side of the drive.
      Ask FixBot
    3. MacBook Core Duo Hard Drive Replacement: step 8, image 1 of 1
      • Lift the silver metal hard drive bracket off of the hard drive.
      • You'll need to transfer this metal bracket to your new hard drive.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      Ask FixBot
614 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
20 Guide Comments
Thanks iFixit for this great walkthrough. Yes, it worked find. Have a look: http://www.vimeo.com/17134347 ;) Keep on rockin' /Sebastian
Sebastian Perschke - Reply Share
Any suggestions for when the rubber track comes out with the hard disk? Short of dismantling the whole thing?
billkline - Reply Share
I saw no replies to the "black rubber lip in the slot" comment. What is the fix for that rubber liner track strip coming loose from the inside of the HD enclosure, please?
Mike - Reply Share
Thanks for the guide, iFixit! It worked like a cham.
scheppdogg532 - Reply Share
I was wondering if there are any harddrives that are known to be incompatible with this MacBook (aside from dimensions of course)?
Jeannine Guenette - Reply Share
Past 24 Hours: 9
Past 7 Days: 53
Past 30 Days: 279
All Time: 438,620
