Up to 20% off select tools
MacBook Core 2 Duo RAM cover replacement
Views: 2.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
28
All Time:
2,216
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
The RAM cover keeps the RAM detachment lever from interfering with the battery and plays a role in protecting the HDD.
    1. MacBook Core 2 Duo RAM cover replacement, RAM cover: step 1, image 1 of 1
      • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
      • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
      • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
      • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
      Ask FixBot
    2. MacBook Core 2 Duo RAM cover replacement: step 2, image 1 of 1
      • Pull the L-shaped RAM cover towards you and remove it from the laptop.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
4 other people completed this guide.
Special thanks to these translators:
jp en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Uhucream
857 Reputation
2 Guides authored
Japanese Translators Member of Japanese Translators
Community
6 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 2,216
