MacBook Air SSD Replacement
Views: 77K
View statistics:
Past 24 Hours:
55
Past 7 Days:
350
Past 30 Days:
1,646
All Time:
77,230
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to upgrade or replace the solid state drive (SSD) on your MacBook Air. The SSD is the storage component of your laptop, responsible for long term preservation of your files and operating system. If your computer is crashing frequently or having boot problems, a corrupted SSD may be at fault.
This guide is relevant for all models of MacBook Air containing a user replaceable SSD, which includes machines released between 2010-2017. If your laptop is newer than that, it's likely got a soldered storage component—sorry, we can't help you here.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Model specific guides for this device are available if you want to dig into the details. For a better experience, you should navigate to your specific model, whether you've got a MacBook Air 11" or a MacBook Air 13", and find the replacement guide that's relevant to you. If you aren't too particular and just need the basics, continue on for the general process.
You can find the replacement SSD that's best suited for your machine here!
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
    1. MacBook Air SSD Replacement, SSD: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case.
      • The two screws on the edge containing the hinge are longer than the others.
      • The eight screws in the corners and remaining edges are shorter.
      Ask FixBot
    2. MacBook Air SSD Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    3. MacBook Air SSD Replacement: step 3, image 1 of 2 MacBook Air SSD Replacement: step 3, image 2 of 2
      • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
      • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
      • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
      Ask FixBot
    4. MacBook Air SSD Replacement: step 4, image 1 of 1
      • Remove a single T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    5. MacBook Air SSD Replacement: step 5, image 1 of 2 MacBook Air SSD Replacement: step 5, image 2 of 2
      • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
      • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
6 other people completed this guide.
Austin Blakely
23,350 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
2 Guide Comments
hi i want to install a new operating system for macbook air high sierra but it say the recovery something something
Justice Mensah Blay Mewube - Reply Share
Thank you for your work, can we get the instructions for the air, not the pro ?
Roger Kapp - Reply Share
Past 24 Hours: 55
Past 7 Days: 350
Past 30 Days: 1,646
All Time: 77,230
