MacBook Air Models A1237 and A1304 Processor Clamp Replacement
    1. MacBook Air Models A1237 and A1304 Processor Clamp Replacement, Lower Case: step 1, image 1 of 1
      • Unplug your MacBook Air and power it off before you proceed.
      • Remove ten Phillips screws securing the lower case to the MacBook Air:
      • Six 2.8 mm screws
      • Two 3.8 mm screws
      • Two 5.4 mm screws
      Ask FixBot
    2. MacBook Air Models A1237 and A1304 Processor Clamp Replacement: step 2, image 1 of 2 MacBook Air Models A1237 and A1304 Processor Clamp Replacement: step 2, image 2 of 2
      • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
      Ask FixBot
    1. MacBook Air Models A1237 and A1304 Processor Clamp Replacement, Battery: step 3, image 1 of 1
      • Disconnect the battery connector by pulling it straight out of its socket.
      Ask FixBot
    2. MacBook Air Models A1237 and A1304 Processor Clamp Replacement: step 4, image 1 of 1
      • Remove the following nine screws securing the battery to the Air:
      • Four 2.9 mm Phillips.
      • Four 3.8 mm Phillips.
      • One 7.2 mm Phillips.
      Ask FixBot
    3. MacBook Air Models A1237 and A1304 Processor Clamp Replacement: step 5, image 1 of 1
      • Lift the battery out of the Air.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Ask FixBot
    1. MacBook Air Models A1237 and A1304 Processor Clamp Replacement, Processor Clamp: step 6, image 1 of 1
      • Remove the 1.9 mm Phillips screw securing the processor clamp to the heat sink.
      Ask FixBot
    2. MacBook Air Models A1237 and A1304 Processor Clamp Replacement: step 7, image 1 of 1
      • Lift the processor clamp off the heat sink.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 112
All Time: 12,906
