Introduction
Your Air is thirsty! Keep those electrons flowing and fix your broken DC-In board.
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the single Phillips screw securing the display data cable ground loop to the upper case.
4 other people completed this guide.
