MacBook Air 15" 2025 MagSafe Port Replacement
    1. MacBook Air 15" 2025 MagSafe Port Replacement, Prepare your Macbook Air for disassembly: step 1, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Prepare your Macbook Air for disassembly: step 1, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Prepare your Macbook Air for disassembly: step 1, image 3 of 3
      • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully power off your MacBook.
      • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
      Ask FixBot
    1. MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the lower case: step 2, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the lower case: step 2, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
      Ask FixBot
    2. MacBook Air 15" 2025 MagSafe Port Replacement, Insert an opening pick: step 3, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Insert an opening pick: step 3, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the center of the lower case's front edge.
      • Pull up on the suction handle to create a gap between the lower case and the frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. MacBook Air 15" 2025 MagSafe Port Replacement, Release the snapping clips: step 4, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Release the snapping clips: step 4, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Release the snapping clips: step 4, image 3 of 3
      • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
      • Slide the pick to the bottom right corner to release the first clip.
      • Slide the pick around the corner and up the right edge to release the next two clips.
      Ask FixBot
    4. MacBook Air 15" 2025 MagSafe Port Replacement: step 5, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement: step 5, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement: step 5, image 3 of 3
      • Insert the opening pick in the original gap created with the suction handle.
      • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
      Ask FixBot
    5. MacBook Air 15" 2025 MagSafe Port Replacement, Release the sliding tabs: step 6, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Release the sliding tabs: step 6, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Release the sliding tabs: step 6, image 3 of 3
      • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
      • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
      • Don't pull up until the cover is completely separated.
      Ask FixBot
    6. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the lower case: step 7, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the lower case: step 7, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the lower case: step 7, image 3 of 3
      • Remove the lower case.
      • During reassembly:
      • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
      • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
      • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
      • You'll hear and feel a distinct click as each clip snaps into place.
      Ask FixBot
    1. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the battery connector cover tape: step 8, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the battery connector cover tape: step 8, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the battery connector cover tape: step 8, image 3 of 3
      Buy
      • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
      • During reassembly, use the leftover adhesive to secure the tape to the cover.
      Ask FixBot
    2. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the battery connector cover: step 9, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the battery connector cover: step 9, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the battery connector cover: step 9, image 3 of 3
      • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
      • Remove the cover.
      Ask FixBot
    3. MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the battery: step 10, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the battery: step 10, image 2 of 2
      • Use an opening pick to pry up and disconnect the battery connector.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
      Ask FixBot
    1. MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the speaker cable and hinge covers: step 11, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the speaker cable and hinge covers: step 11, image 2 of 2
      • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
      • Use a 3IP Torx Plus screwdriver to remove the following screws:
      • Two 2.6 mm‑long screws securing the right hinge cover
      • Two 1.5 mm‑long screws securing the speaker cable cover
      Ask FixBot
    2. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the covers: step 12, image 1 of 1
      • Remove the speaker cable cover.
      Ask FixBot
    3. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the right hinge cover: step 13, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the right hinge cover: step 13, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the right hinge cover: step 13, image 3 of 3
      • Insert the point of a spudger into one of the right hinge cover's screw holes.
      • Push the hinge cover away from the back edge to dislodge it.
      • Remove the hinge cover.
      Ask FixBot
    4. MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the left speaker: step 14, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the left speaker: step 14, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the left speaker: step 14, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the left speaker press connector.
      Ask FixBot
    5. MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the left speaker: step 15, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the left speaker: step 15, image 2 of 2
      • Remove the three screws securing the right speaker:
      • One 5.5 mm‑long 4IP Torx Plus screw
      • One 2.7 mm‑long 4IP Torx Plus screw
      • One 3.5 mm‑long T6 Torx screw
      Ask FixBot
    6. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the left speaker: step 16, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the left speaker: step 16, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the left speaker: step 16, image 3 of 3
      • Make sure the cable on the top left edge of the speaker doesn't get caught on the logic board, as it may tear.
      • Lift the speaker's right edge over the frame and slide it to the right to remove it.
      • During reassembly, slide the speaker cable under the right edge of the antenna bar assembly before laying the speaker in its recess.
      Ask FixBot
    1. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the right ports cover: step 17, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the right ports cover: step 17, image 2 of 2
      Buy
      • A piece of tape on the right edge of the logic board hides the MagSafe and USB-C port connectors cover.
      • Use blunt nose tweezers or your fingers to peel up and remove the tape.
      Ask FixBot
    2. MacBook Air 15" 2025 MagSafe Port Replacement: step 18, image 1 of 3 MacBook Air 15" 2025 MagSafe Port Replacement: step 18, image 2 of 3 MacBook Air 15" 2025 MagSafe Port Replacement: step 18, image 3 of 3
      • Use a 3IP Torx Plus screwdriver to remove the three 1.5 mm‑long screws securing the port connectors cover.
      • Remove the cover.
      Ask FixBot
    1. MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the MagSafe port: step 19, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Disconnect the MagSafe port: step 19, image 2 of 2
      • Use a spudger to pry up and disconnect the MagSafe port press connector.
      Ask FixBot
    2. MacBook Air 15" 2025 MagSafe Port Replacement, Separate the cable adhesive: step 20, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Separate the cable adhesive: step 20, image 2 of 2
      Tesa 61395 Tape
      $2.95
      Buy
      • Light adhesive secures the MagSafe port cable to the frame.
      • Slowly peel the MagSafe port cable from the frame to separate the adhesive securing it.
      • If your new MagSafe port's cable comes with adhesive, remove the plastic liner and press the cable into place on the frame.
      • If the cable doesn't have adhesive, use a strip of double-sided tape to secure it to the frame.
      Ask FixBot
    3. MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the MagSafe port: step 21, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Unfasten the MagSafe port: step 21, image 2 of 2
      • Use a 3IP Torx Plus screwdriver to remove the two 3.3 mm‑long screws securing the metal wedge to the MagSafe port.
      • This wedge keeps the port secure in its recess.
      • Use a 5IP Torx Plus screwdriver to remove the two 2.7 mm‑long screws securing the MagSafe port to the frame.
      Ask FixBot
    4. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the wedge: step 22, image 1 of 1
      • Remove the wedge from the top of the MagSafe port.
      Ask FixBot
    5. MacBook Air 15" 2025 MagSafe Port Replacement, Remove the MagSafe port: step 23, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Remove the MagSafe port: step 23, image 2 of 2
      • Remove the MagSafe port.
      Ask FixBot
    6. MacBook Air 15" 2025 MagSafe Port Replacement, Install your MagSafe port: step 24, image 1 of 2 MacBook Air 15" 2025 MagSafe Port Replacement, Install your MagSafe port: step 24, image 2 of 2
      $3.99
      Buy
      • Follow this step to install your MagSafe port.
      • The screws will be drawn toward the magnet in the port. You may need to use angled tweezers to hold the screws in place while tightening them.
      • Insert the port and use a 3IP Torx plus screwdriver to partially tighten the two 2.7 mm‑long screws that secure the port's left edge.
      • Properly align the port and fully tighten its screws.
      • You can plug your charger in and use it to align the port, but make sure it's not plugged into power.
      • Put the wedge into place on top of the MagSafe port and use a 5IP Torx Plus screwdriver to partially tighten the two 3.3 mm‑long screws.
      • Push the wedge under the lip of the frame and fully tighten its screws.
      Ask FixBot
Spencer Day
202,459 Reputation
1,244 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 42
All Time: 103
