MacBook Air 13" Mid 2013 Solid-State Drive Replacement
    1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
      • Two 9 mm screws
      • Eight 2.6 mm screws
      Ask FixBot
    2. MacBook Air 13" Mid 2013 Solid-State Drive Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Battery Connector: step 3, image 2 of 2
      • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
      • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
      • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
      Ask FixBot
    1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Solid-State Drive: step 4, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Air 13" Mid 2013 Solid-State Drive Replacement: step 5, image 1 of 2 MacBook Air 13" Mid 2013 Solid-State Drive Replacement: step 5, image 2 of 2
      • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
      • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
Not sure what to do with your old SSD? Use this external SSD enclosure to turn it into a handy portable external drive!
148 other people completed this guide.
31 Guide Comments
May I upgrade it to a 256 GB Drive?
Ray - Reply Share
Where can I find the 256GB SSD to upgrade my 128GB macbook air (mid 2013)?
Josh - Reply Share
I'm also looking for a 256HB SSD because 128GB isn't enough?
rhattan503 - Reply Share
At the moment, the only source for this part is on eBay, at UpgradeMonkey shop (UK)
Link : http://www.ebay.fr/itm/NEW-haswell-MacBo...
It's high priced, but I didn't find anywhere else.
Regards.
JMM - Reply Share
http://www.alelua.com/es/31-almacenamien... SDD for MacBook Air 11" and 13" (Mid 2013/Early 2014) 256 GB Drive
alelua - Reply Share
Past 24 Hours: 20
Past 7 Days: 86
Past 30 Days: 393
All Time: 376,582
