MacBook Air 13" Late 2010 Lower Case Replacement
    1. MacBook Air 13" Late 2010 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 9 mm 5-point Pentalobe screws
      • Eight 2.6 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 13" Late 2010 Lower Case Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
6 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 104
All Time: 11,397
